![]() Join Date: Sep 2009
Well im cleaning up my engine bay, but i want to take out that ugly airbox. So I just wanted to know if i can put a new air filter but keep the stock intake?
![]() Join Date: Dec 2007
Trader Rating: (30)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 30 reviews
I assume it is possible but ca smog requirements may restrict you from modifying the intake. Besides the smog issue, an maf adapter for air filter, and inlet air temp sensor adapter is what you would need. Most people just let the inlet air temp sensor hang loose since there are not many adapters available for this.
~m
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202 Read My Sales Review 626 Friday Nights San Gabriel Last edited by let5l1de; 11-08-2009 at 11:56 PM.. Reason: spelliing |
![]() Join Date: Nov 2008
Trader Rating: (31)
![]() Feedback Score: 31 reviews
its possible but like mario said its against ca smog requirements
plus it burns ups MAFs which leads to idling issues. just save up for a used carb legal intake. you can get one on here for around 75 bucks. just be patient for a good deal, its always better to buy legit parts the first time instead of wasting money on crap. ![]() |
#4 | |
Trader Rating: (31)
like i said before.. you can do it.. but you will regret it later. it WILL burn up your MAF. you will have to keep giving your car gas to make it idle. if you dont it will just stall. my friend did that on his intake and burnt up like 4 mafs before he got the picture |
K&N makes a nice intake setup that is not too expensive, but most importantly it is CARB approved and comes with the sticker with the CARB number on it to keep the smogman happy. Then you can lose the airbox...
#9 | |
Trader Rating: (31)
have you ever put a cone filter on a stock intake tube like the OP was talking about doing??? go put one on and drive around for a day then tell me how well your car idles |
AFC #1
![]() Join Date: Oct 2003
K&N makes a great application that bolts in place of the stock air box like you want and has a CARB EO.
57-6000 - K&N 57 Series FIPK, Performance Intake Kit
Trader Rating: (30)
The only problem with a wet type filter is, you can over saturate the element. With the light weight K&N oil, guess where the additional oil is sucked into and what sensor it may contaminate?
Regardless, IMO K&N is a great filter manufacture. ~m
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202 Read My Sales Review 626 Friday Nights San Gabriel |
![]() Join Date: Jun 2007
As an at heart musclehead, I'd say just replace the stock air filter with a better one. I've seen alot of 500+hp v8's with the stock airbox... Which is good for you because of CA's emissions laws.
Then again, 4cyls are a tad different. You can try modifying your stock intake box a little to help breath better. remove the baffles and what not, get a better filter. Its cold enough over on that side it won't make a huge difference if you take off them there fresh air tubes. And K&N manufactures the air filter for the M1 Abrams tank... just a little FYI
BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
#13 | |
AFC #1
K&N Response to Mass Air Flow Sensor Concerns http://www.knfilters.com/common_misdiagnosis.htm
Admin Asshole
![]() Join Date: Mar 2002
I have put K&N drop in filters in every vehicle I have owned. Never had a complaint.
K&N ![]()
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#15 | |
Trader Rating: (30)
lol @ failure. Someone else must have posted failure.... And since when have we taken one test from any manufacture as the answer for every application or situation? -- Ok here is my experience. I was employed with SuperShops for 6 years and also worked with CarCustom for over 4 years, not to mention my personal experience of 18 years. As you may already know, SuperShops was one of the top 10 retailers of K&N filters. With the volume of sales, we saw everything come in to us regarding feed back on many parts sold throughout the chain of over 170 stores nation wide. Anyway, I was serious v8 gear head. My love at that time was small block Chevy 1st gen and SB2 engines. I also used the E-3750 (14"x4" round) element in a drop-base bottom with the chrome K&N logo top. This is where I encountered my first oil collection found on the inner lower lip of the filter assembly. I contributed the collection due to ambient under the hood temps and possible over-saturation. AirCooled Volkswagen (yes i know...) was another fun time for me in the performance industry (may the "vw and performance is an oxymoron" comments begin). Long story short, over-saturated K&N filters sitting on flat based, almost non recessed bottoms on top of Weber or Dellorto downdraft carbs (especially with outerwears) showed the signs seepage onto the venturis. This wasn't a big deal since VW's are notoriously known for carb rebuilds and oil leaks among others... Who is to say this could not happen with a saturated tapered or oval style filter? IMO, K&N filters were and still are one of the best filter mfg's (as stated earlier) in the performance industry. I personally have sold many hundreds, maybe over a thousand of the K&N filters, installed hundreds K&N products and customers serviced probably over a thousand times. The large majority of my installations as well as customer installs have worked in near flawless performance. As with any manufacture, we do come across situations we would have never guessed could have happened. Once the product has reached a customers hand, anything is possible... ANYTHING! ~mario
#16 | |
![]() Join Date: Feb 2006
Why? K&N makes the best air filters on the planet. Open your mind. |
#17 | |
![]() Join Date: Jan 2004
-sell your 240sx -eat a gun
#19 | |
#20 | |
Trader Rating: (31)
![]() of all people why would you call out a mod?? he gave you a legitimate answer for your question. if you wanna go with a egay setup then go for it.. but what was the whole purpose for this thread?? ![]() ![]() ![]() |
#22 | ||
AFC #1
I don't see how your anecdotal evidence proves anything. Quote:
Ebay filters are usually cheap paper shit that looks like a K&N. It won't work the same and will clog up after 15k. K&N will be good till 50k. Foam filters break down over time and shit goes into you intake. I have had people with green foam in their maf. You have a KA which is legal so why not keep it legal?
#23 | |
Trader Rating: (30)
I may be a victim of my own cognitive bias at times. However, we are all entitled to our subjective validation. Hence, my personal experience as stated above. We should request K&N to release or conduct more real time R&D studies of each individual filter types for increased consumer/public knowledge. ![]() ~m
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202 Read My Sales Review 626 Friday Nights San Gabriel Last edited by let5l1de; 11-09-2009 at 01:51 PM.. Reason: spling |
#24 | |
what does this mean, clean up your shit? is the stock airbox in some way dirty? based on the nonsense you post, i'm sure the engine bay is caked in grime, has exposed wires, etc, and you probably have a smashed in quarter or something severe that needs attention more than replacing a functional filter with some noname shit off ebay. you're a moron, kid.
#25 | |
#26 | |
#27 |
[quote=soreballz;3125377]Kids these days...
[/quotewhat do you mean kids theese days, people here are the one making me look like a noob i just asked a simple question about filters there, dont post if you got nothing good to say, |
#28 | |
well its like if you have an sr and then you want to put a legal intake and shit , so thats retarded its already illegal, thats my point... idgaf thats why my shit it not legal, my car is all motor with engine rebuild, i have megan racing testpipe and headers, .. i know it aint fast but it sound nice, but i could still get pulled over, so whats a legal intake gonna do, make it legal? .. not a damn thing, so i want something not legal i dont want k&n ![]() ![]() |
#29 | |
Clear now? Good. |
#30 | |
Keep the airbox, or donate it to me. I can not stress that enough. |
