Old 11-01-2017, 12:34 PM   #1
tougefactory
tougefactory's Avatar
Touge Factory S13/S14 240SX OIL CATCH CAN (SR/KA/LS)
The purpose of an oil catch can is to catch the rerouted oil and other contaminants expelled from the PCV Valve before entering the combustion chamber which can cause knock or pre-ignition.
Cheaper oil catch cans are empty inside without any type of baffling or filters, but TF oil catch cans are baffled and contain steel wool to reduce the amount of contaminants in the engine.
Also, properly designed oil catch cans reduce carbon build-up on the valves, which can ultimately hinder engine performance.
Our oil catch can is specifically designed to fit directly under the wiper motor in the engine bay for LHD S13/S14.
This location is on the oil filter side of the KA/SR. is out of the way and is aesthetically pleasing.
It comes with 2 -10AN fittings with an easy to see fluid level tube and also an easy-drain plug that you can easily drain without removing the catch can from the engine bay.
Our catch cans have a 1.5 quart of fluid capacity and each catch can is hand-made and checked for leaks prior to shipping.
If you need to us to make custom lines for your setup, please feel free to contact us!
*PLEASE NOTE THIS CATCH CAN WILL NOT CLEAR CRUISE CONTROL AND A/C EQUIPPED CARS AND WILL ALSO NOT WORK ON RHD CARS*
PRICE: $395 SHIPPED
Old 11-02-2017, 10:24 AM   #2
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
looks pretty sick, bummer that it won't fit with heater core lines.
Old 11-03-2017, 08:03 AM   #3
tuzzio
tuzzio's Avatar
I'd like to see pictures of it mounted. It seems like it mounts to the back of the strut tower, I don't see why it wouldn't clear heater hoses.
Old 11-03-2017, 08:04 AM   #4
tharocket
tharocket is an unknown quantity at this point
I agree I was racking my Brain about why it would affect all those systems if it got that curve and would mount behind the strut tower.
tharocket is offline   Reply With Quote
Old 11-03-2017, 09:31 AM   #5
tougefactory
We have some pictures on the way. Waiting for our photographer to snap some pictures. There installed on our S13/S14 shop cars.
Be on the look out!
**CORRECTION, THIS OIL CATCH CAN WILL NOT AFFECT THE HEAT CORE LINES**
Apologize for that!
Old 11-03-2017, 10:12 AM   #6
tuzzio
tuzzio's Avatar
Originally Posted by tougefactory View Post
They're* installed on our S13/S14 shop cars.
Corrected. That makes more sense about the heater lines. Will keep checking back for installed pictures.
Old 11-09-2017, 01:12 PM   #7
tougefactory
Pictures are here!! Sorry it took a little awhile. Very busy in the shop.
s13 s14 sr20det ka24de
