Old 04-03-2017, 05:13 PM   #1
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
SR20 PCV valve
Would I be okay to T my PCV hose into the brake booster line off the intake manifold? I have a Greddy style manifold and only one big fitting is available. I don't see how it could cause an issue.
Frank_Jaeger is offline   Reply With Quote
Old 04-04-2017, 07:26 AM   #2
jedi03
might lose brake pedal assist...I thought about this last night as I was thinking about where to pull vacuum from my exhaust...
Old 04-05-2017, 11:03 AM   #3
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Run your PCV to the turbo inlet.
My SR20VET
Old 04-07-2017, 07:53 AM   #4
jedi03
that's the stock location for the driver side of the engine...the manifold needs an additional nipple to use the stock pcv location...running it to the turbo inlet or your intake with a catch can seems to be the usual setup
Old 04-07-2017, 01:11 PM   #5
Frank_Jaeger
I'll T into that then! Makes more sense. Right now I'm going to run a stockish setup before I run lines from the extra bungs on my valve cover to the exhaust.
