S13 cluster problem
So my 1989 240sx hatchback had an issue with the stock cluster: the oem temp gauge stopped working (replaced the sensor and verified wiring was working), and the speedometer would overstate speed intermittently so I was told to replace the cluster.
I ordered an S13 JDM cluster 180kmh cluster from another user on this board, and the cluster was in great shape with only 14k original km. I swapped the clusters and found that only the left half lit up so I replaced the bulbs with the ones from my old cluster and it still wouldn't like up. Next I take it for a drive and only the warning lights work: the gas gauge, speedomoter, tach and temp gauge now do nothing. What do I do? |
So, I just took the dash apart and confirmed that all the connections were well seated and that they can't be put in backwards. When I remove the far left multipin connector the car died, otherwise with connections reseated, there was no change in the display functionality. I then swapped back in my old gauge set and voila, the tach and gas gauge work immediately. I haven't test driven it to confirm that the speedo works again but since it is my original gauge set I presume that it will.
I thought that all DOHC S13 gauge sets were interchangeable? Could I have gotten an SOHC gauge set by mistake? |
#3 | |
1991 240sx Hatch Daily'd! |
