03-27-2012, 11:27 AM | #1 |
rb no spark please help
ok so i have a rb25 s2 motor in my s13. the motor was pulled from a rx7 and was sold to me. motor ran and started fine in the fd but when i put it in my car im getting no spark. i have a plug n play harness i got from ws and using the same ecu as the kid was using in the rx7. now im getting power and ground from my coils but no pulse. could it be a ground issue? remember the motor started and ran fine in the rx7 so im sure the sensors and ecu is fine. but im not sure wht could be the problem. any ideas or thoughts would help. i need to get this car running asap. please help thanks.
03-27-2012, 11:30 AM | #2 |
also want to throw this out there... the ecu has no mounting bracket but where the mounting bracket should be, looks to be some kid of leads. like if i open the ecu the leads go into the ecu and kinda look like a ground but not sure. so idk if i need to ground the ecu itself by bolting it down... i just dont have the bracket but if needed ill rig somthing
