Old 10-23-2014, 02:45 PM   #1
brianglawson
brianglawson's Avatar
brianglawson is an unknown quantity at this point
Send a message via ICQ to brianglawson Send a message via AIM to brianglawson Send a message via Yahoo to brianglawson
s14 S14 OEM Link Length? Toe Rod, Traction Rod, and Camber arms.
Hey guys, Im looking for the OEM length of S14 Links. I'd like to get the length from the center of the bolt hole to the center of the other bolt hole
The Rear Toe Rod
The Rear Traction Rod
The Rear Camber Arm
The only OEM link I have is the Front Tension Rods, The rear of my car came with adjustable links.
Im installing new coilovers and z32 rear brakes and noticed that NOT A SINGLE lock but on any of my adjustable links were locked... I also notice that my traction rods seem to be a bit long. Now I have searched and found that they are supposed to be 8.25 on S13's, but haven't found the OEM length for the S14.
I just want to set all of these Adjustable Links to the OEM length so my alignment guy has a good place to start, and more importantly, so my car isn't just ridiculously out of whack when I have to drive it there.
S15 SR20DET Powered, Kouki S14 #/f/showthread.php?t=578575
brianglawson is offline   Reply With Quote
Old 10-28-2014, 11:23 PM   #2
omgosh
omgosh is an unknown quantity at this point
http://www.nissanroadracing.com/showthread.php?t=1652
omgosh is offline   Reply With Quote
