![]() Join Date: Feb 2009
Trader Rating: (47)
![]() Feedback Score: 47 reviews
ca18det PART OUT COMPLETE SWAP!!!
looking to part out my ca18det.
Ca18det head REBUILT 1month old! Head was rebuilt by Carters Automotive down here in Oklahoma Asking $200.00 Pistons with rods. One Rod needs work done. Scares need to be fixed. I did ask Carters Automotive if they can fix it, they said they can. Asking $140.00 Ca18det BLOCK GOOD useable block. Low miles, will be perfect for a build! $200.00 Ca18det Turbo $120.00 Ca18det manifold $30.00 Ca18det injectors $SOLD Ca18det Flywheel $35.00 Ca18det clutch $50.00 Ca18det 5 speed Tranny $SOLD Ca18det valve covers $SOLD Ca18det Water pump $30.00 Ca18det Oil pump $50.00 Ca18det Front conver $20.00 Ca18det CAS $65.00 Ca18det INTAKE MANIFOLD COMPLETE with out injectors. $SOLD Sr20det SMIC $30.00 Ca18det ignitor $SOLD Ca18det mass air flow sensor $SOLD Ca18det ECU $SOLD Ca18det Coverted to s13 wire harness $SOLD Ca18det motor mounts (same as 240sx) $25.00 Ca18det coil packs (work) $70.00 ALL 4 Ca18det coil pack wire harness $20.00 Ca18det AC with bolts and brackets $50.00 Ca18det power steering with bolts and brakets $sod ca18det alternator $40.00 with brackets and bolts! Ca18det cams! $30.00 Ca18det ANYTHING ELSE! 100% Complete Swap. WHOLE SWAP $300 what is left! I can meet half way! Located in Oklahoma City SO PLACE YOUR ITEMS YOU WANT. ![]()
![]() Join Date: Jul 2003
I need the rubber hose that goes between the cold pipe and the throttle body for my KA24DET. Will you sell just the hose (on the cheap) and ship it to 48197? PM me. Thanks. See pictures.
96 S14 SE with T25 KA24DET |
#8 | |
Trader Rating: (47)
Yes the wire harness sold as well. If you want to purchase the whole motor, please put a down payment so I will stop the part out.
#21 |
please email me if you have the power steering stuff.. [email protected]
#23 |
![]() Join Date: Feb 2008
Trader Rating: (28)
![]() Feedback Score: 28 reviews
Old thread but any chance on what parts I need to complete a power steering and AC install on my CA18DET S13 coupe???
Dream to achieve!!! |
