![]() Join Date: Oct 2008
Trader Rating: (30)
![]() Feedback Score: 30 reviews
Garage Sale, S14/S13/Z32
Willing to ship anything and can give quotes, buyer is responsible for shipping cost. Prices do not include shipping. Reply here or PM me with any questions. Can provide more pics of anything. Thanks for looking.
Z32 e-brake assembly $75 ![]() ![]() BNIB Viper Alarm system, bought a few years ago from Broadfield never used, $150 Viper 3202 522T Trunk release solenoid 520T Battery Backup System 507M Digital Tilt Motion Sensor ![]() Marshall Gauges - also BNIB, opened to look at but never installed. these were $550 or so new. looking to get $350 for the set Speedometer, Tachometer, Oil Pressure, Water Temp, Boost ![]() Wiring harnesses from '95 240SX. all but the Main harness ![]() S14 Silvia K's gauges $50 ![]() ![]() S14 SR20DET Kouki (NA code) ECU. Says "JDM of Miami" on it, unsure of the tune (if any). Tested on my car and it started. $100 ![]() ![]() S14 SR20DET Kouki to S13 240SX chassis engine harness. Got this from a guy on here, not the cleanest job, I never tested its functionality myself. Broken connector in pic below. $50 ![]() ![]() S14 SR20DET Kouki engine harness. Stripped the insulation off and started labeling things, didn't finish, it's all there. $100 ![]() ![]() S13 dash with those two cracks there. Good shape otherwise. $10 ![]() S14 dash. Has 3 small holes in the center where some gauges were. 2nd pic for hole size reference. $30 ![]() ![]() S13 gauge cluster surround. good shape, no cracks or anything. couple switches missing. $10 ![]() S14 OEM rear hubs/uprights/dust shield $50 ![]() ![]() ![]() S14 steering column, missing the blinker stalk. has key in the cylinder $50 ![]() ![]() ![]() S13 KA24DE, 180K on the clock, ran great when pulled, typical oil leaks. no PS pump or bracket, coolant temp sensor for gauge is not there, header is cut near the back. $200 picked up. can help load it up. ![]() ![]() ![]() S13 cluster, not sure condition but it worked years ago. 112k on the odo. $40 ![]() S14 SR20DET OEM radiator. missing the drain plug on bottom. $50 ![]() S14 KA24DE OEM header. $50 ![]() S14 Cusco RUCA, seem to be in good shape, nothing binding and moves smoothly. $200 I'll get better pictures once I get them off the car, just wanted to get them posted. ![]() S14 Cusco Tension rods, also good shape $175 ![]() S14 ISIS/ISR Traction and Toe Links $75 per set ![]() ![]() S14 HKS Coilovers - unsure of the model, all they say is HKS Damper. Came with a Silvia clip. $600 Never drove on these but the car sat on them for a minute. No leaks or anything like that, seem to be in good shape. ![]() ![]() ![]() ![]() ![]() S14 misc things, throw some offers ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks Last edited by phunc; 10-30-2016 at 08:43 AM.. Reason: price reduction |
![]() Join Date: May 2009
do you have the splash shield that goes under the engine for a S14?
This is a site ran by the US government, not some crazy biased organization |
![]() Join Date: May 2011
Interested in the rear hubs if the bearings are alright, but i'd need them shipped to 30101 and I'm not really interested in the dust shield or uprights. Any chance you'd be willing to separate? PM me if you want to work something out. Thanks
