Old 07-03-2009, 08:30 PM   #61
GSXRJJordan
GSXRJJordan's Avatar
Originally Posted by Choku_Dorian View Post
meh...
that was my reaction until the first lowered pic, my jaw actually dropped. not too many cleeeeaaaaaan, simple r32's like that they usually have goddy kits or wings and what have you.
also, you fail o cover like any part of the awd swap, im guessing its fairly bolt on? what parts did you use (i saw the tranny comment) but i wouldn't mind some details.
nice car man.
He started with a GTS-4, it came AWD with the same Atessa (sp?) setup as the GTR. No swap work involved, unless you consider swapping oil pans a swap.
Old 07-04-2009, 07:49 AM   #62
Sil-Eighty SE-K
Sil-Eighty SE-K's Avatar
Sil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfection
Send a message via AIM to Sil-Eighty SE-K
Yup exactly as he said.... It was a straightforward "swap"
my chassis already has all the atessa/hicas parts (pump, computer, gsensor etc) so I just used the gtr transmission (the gts 4 is the same with different gearing and I've read it's not as strong... Not sure how true that is) at that point I'm running different gear ratios between the front and read diffs which is obv bad so I had the choice of getting a gtr rear diff or using my rb20 front diff.... I was broke at the time so I just swapped front diffs/pans
Originally Posted by JTunedMotorsports View Post
get off the thread...no one cares...
Sil-Eighty SE-K is offline   Reply With Quote
