![]() Join Date: Apr 2002
this is what i had. s-13 black top. i droped a valve which basicaly took out the head and block. basicaly the motor is roached. my question becomes weather or not to replace it with another det or just gut a rwd de. i know the compresion is higher, but how much higher im tol either 9.5 or 10:1.
i plan on changing the cams, springs, and using rocker arm stopers, retainer etc. so this does not happen again. if tuned well how much power can the stock de botom end hold. piston oil squirters are great but how much do they help? im told the rods and crank are the same i can change the oil pump to a turbo model. ive her of sentras puting 427 to the wheels stock botom end. let me know what you think
Twin67 ls1/awd in the works Last edited by Racer X; 11-23-2003 at 10:32 AM.. |
Sorry, I can't really answer your question on the DE.
But, I was just wondering what caused you to drop a valve on the blacktop?
![]() Sleep Doesn't Drink Beer |
im not too sure i guess too much rev limiter bouncing. my car stays side ways. the one day i go drag racing second run i herd rattling, loud rattling i coasted off the track and there was a hole in valve cover. part of the rocker arm shot out. ( may be over rev?) if i had rocker arm stoppers this probaly would not have happened. everything would have been fine had just the arms broken but one of the valve retainers broke too causing the valve to drop.
Twin67 ls1/awd in the works |
Zilvia Contributor
![]() Join Date: Oct 2001
![]() ![]() Feedback Score: 1 reviews
Heres an SR blacktop longblock on ebay for $250.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2443775330 You could swap stuff off your old motor and put it in this one. -m
400x200
thanks for the heads up but that is an s-14 block and it said it was tested bad. i guessing as in bad compression.
