![]() Join Date: Nov 2011
So I went with a ca swap I picked up from an importer this year. I redid most gaskets, all belts, and all the hoses. I wired or correctly(solder, heat shrink, wrapped with elec tape). It's been blowing white smoke since the first start and it smells strongly of fuel. It studders really hard on start up, mostly cold starts. Also, it misfired at idle and up to about 3.5k-4k. Oil smells like gas. It's only idled for a total of an 1.5 hours and a few drives around the block which is a very small distance.
Things I've done: Compression test(150,149,149,150) New fpr set to 28psi with vacuum. Changed oil. Changed spark plugs. Checked resistance across injectors and coil packs New o2 sensor Mods: Tomei fpr Hks ssq bov VTA Aftermarket manifold Full 3" apexi exhaust Water to air intercooler setup CAI Boost gauge Waiting on my oil pressure gauge Sr20 clutch&flywheel setup Aluminum radiator with elec fan Kade tb with ca tps Weapon r catch can Any help would be greatly appreciated! Last edited by purplove; 01-26-2013 at 10:41 AM.. Reason: Jsnsns |
first, set your fuel pressure a 35psi without vacuum
second, check your mass return from your injectors, if it's there continuity between injectors and the chassis, your ECU has a problem (injectors are opening to the chassis mass only via the ECU) if you can, use an OEM FPR. how is plugged your OCT? |
My fuel pressure is set to 36 psi without vacuum which is correct according to the fsm.
My oem fpr showed 36 psi with vacuum which is why I switched over to the adjustable. What is an OCT? I will check for continuity tonight or tomorrow. Thanks for the advice guys, anyone else feel like chiming in? |
also, check your spark plugs, if one is darker than the other, that is the problem cylinder. if it is darker than the others, check the injector and ignition on that cylinder. if all of them are the same color which should be dark because its running really rich. check and make sure the wires you fixed dont touch other wires. and try not to keep the engine running in this condition or you will mess up the bearings and piston rings due to fuel diluted oil.
It been raining alot down here lately and my cars outside
![]() Ill check the plugs, probably even scoop up some new ones. I havent driven the car but twice around the block when I first got it started. It ran great besides the misfires and white smoke everywhere. I got my oil pressure gauge back from megan racing. Oil pressure is steady at 46psi. Thanks for the help guys, Ill be reporting back shortly. |
Have you checked the timing? Make sure all the timing marks on the timing belt line up.
Also make sure your key on the exhaust cam for the CAS isn't broken. You can also try swtiching out MAFs, a KA-e MAF will work.
Shoot To Thrill |
#9 | |
![]() Join Date: Jul 2011
Sent from my iPad using Tapatalk |
#10 | |
Or you can hack up the male plug of the KA maf to accept the female CA end MAF plug.
Shoot To Thrill |
