Max boost pressure for methonal injection?
Hey there,
I'm planning on running Methonal injection into my s14 sr20det. It still has the stock t28 on it with a fmic. I'm currently running 12psi on it. From what I've heard, Max boost on a t28 is like 15-16psi before it becomes inefficient. Therefore no point in increasing boost. My real question is.. by increasing octane or lowing intercooler air temp, is it possible to increase the efficiency threshold of the Turbo? I have an dsport article here on my dropbox you can see that they Methonal injected a s15 sr20det with 91 octane and increased the boost from 15.6 to 24. https://www.dropbox.com/s/jixvaapf6l...cle-pdf-42.pdf I would assume both s14 and s15 Turbos are similar. Thanks for the help
You cannot increase the max CFM a turbo can push by changing fuel. The higher boost you run the higher the air temps become. Outside of its efficiency island your pushing hot air. Methanol will help cool this down, but it is by no means a saving grace. If you want more power, you need a bigger turbo period.
I'm not saying you won't be able to make some more power, because you will be able to just by pushing the knock threshold back some with the meth. However, you aren't getting more air out of a maxed T28.
My SR20VET |
Read what he typed again. He didn't say I wouldn't make more power. He said the Turbo wouldn't push anymore air and the air temp would go down. Did you even read the article?
It's likely that since the meth is cooling the air charge down more than just the intercooler, you will make some more power. However, at the same time, you've already maxed out the compressor, so you aren't going to make much more power. In the end, I think your gains are going to be negligible and ultimately a waste, as Waxball stated. Not to mention you run the risk of the turbo ingesting itself from over spinning it and possibly hurting more components on your setup.
My SR20VET |
I need some more opinions on this. How can you tell how much boost to increase safely? What things do they monitor? I'm thinking it's all done on the dyno. Thanks to you both for your response.
I'd say most gains were the increase of higher octane rating and being able to change the amount of timing the engine was seeing. 24psi is a recipe for disaster on a T28 turbo. You do what you want, but I would never recommend that to anyone.
Take a look at the T28 compressor map if you don't believe that the turbo is way outside its efficiency islands at that pressure. The comp map shows that at 24 psi you'd be running north of the 2.5 mark on the map. This happens to be well outside the efficiency islands. Your also spinning the turbo well over 150k rpms. Even at 20psi your still at the edge. 24+14.7/14.7= 2.63 20+14.7/14.7= 2.36 If you want more power reliably, up your turbo size and add meth.
My SR20VET |
![]() Join Date: Aug 2006
Trader Rating: (-1)
![]() ![]() Feedback Score: -1 reviews
Can we open this topic up more and discuss water meth injection in general, stories and feedback from all engine types? Typical prices and results etc ? Subscribe for more info
We already have a meth injection thread...
My SR20VET |
#11 | |
They were previously limited on power due to 91 octane. With the meth/water injection decreasing the air intake temps while also upping the octane level, they could safely turn up the boost and adjust timing to make more power. I would say that by adding water/meth with a stock T28 that you'll see some results as long as you're able to adjust fuel and timing accordingly, but not on the level that the magazine saw. The turbo just doesn't flow that much. Btw, I'm a big fan of water/meth injection and run an AEM kit on my car. More discussions in this thread: #/f/showthread.php?t...anol+injection |
#12 | |
The same stuff going on in the thread can be generally used for all engines but if you don't mind, since I started the thread, I'd like to keep it aimed for my specific type of engine. You can start a new thread and post a link for this setup in that thread.
#13 | |
Perhaps you should research water/meth injection a little bit. The alcohol in meth increases the octane rating. How much is dependent on how much meth you're injecting.
My SR20VET |
I'll take your advice. I'm currently running 94 pump gas. If I add 50/50 water to Meth, how much octane is it adding?
#16 | |||
GM2 (SW/AW)
I'm not a big meth informant. But I think he was trying to say, depending upon the amount of alcohol (fuel) is in the Meth, that will up your octane rating. Telling us that your mixture is 50/50 meth/water doesn't tell us what your meth/alcohol mixture is. Quote:
The whole purpose of the alcohol in the spray is to turn the "water" into a fuel charge, instead of being just water vapor which would not cause any increase in power because the water would dull down the original mixture of fuel being pressurized in the cylinder. BUT because the alcohol is being introduced with the water, it acts as if it was injecting cooler more dense gasoline.
#17 | |
Sorry guys for being noobish. Im learning stuff here. Thanks for all the feedback.
You can up the efficiency of the turbo by using water injection pre-turbo.
But I wouldn't. The best way to make power is a quality injection system that can safely inject 100% meth a little before the throttle body. Meth is typically 113 octane but that is less important that is cooling effect and burn rate. I'm not a fan of 50/50 water meth. Waste IMO. Meth will allow you to run far more boost and timing all while running 93 pump has in the tank. www.Alkycontrol.com is the best kit. Julio runs his own product in his 8.50 pump gas mustang as well as other personal cars for the last 15+ years. His kits are 100% methanol compatible and he recommends running 100% methanol. VP M5 is the methanol to use.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
#19 | ||
GM2 (SW/AW)
As I said I'm not a "meth head" I don't know much about it, but surely there are different levels of meth additives. Not just a standard mixture. I'm almost positive like octane ratings of fuel, you can up, and up, and up, a mixture of meth/water to boost your HP even more and more.
#20 |
50/50 is just you mixture ratio. What is actually being injected into you motor via the nozzle is what is going to effect your octane rating. Like I said, do some research as I do not have all the answers and do not run a meth injection system. Tom N has more knowledge than me on the matter.
My SR20VET |
#21 |
For the most part methanol is all the same aside from some blends being oxygenated and also having lubricant added in it. VP M5 is oxygenated methanol with lubricant all ready in it.
VP M1 is just strait methanol like southern racing methanol and other brands of strait methanol. Mixing meth with water is a waste. For one they don't mix. Only reason some alcohol injection system suggest it is their crap pumps and cheap push lock lines aren't suited for pure methanol. Get a good system and run pure methanol. The results are well worth it. >>>> www.alkycontrol.com Julio will answer any question you have.
#22 | |
#23 | |
In short I would just use regular methanol. I can get a 5 gallon can of strait methanol for $35
#24 | |
Here is a link I found on the site. Lots of useful information: http://www.alkycontrol.com/faq/acfaqs.html EDITED: I see they sell them from 500-800 on ebay. Home depot sells 3.78L (which is think is close to a gallon) for $10.97 CAD. It is 99.9% pure methanol. I think thats the cheapest I've seen
