Old 09-27-2011, 10:24 PM   #1
shibbyRPS13
shibbyRPS13 is an unknown quantity at this point
SR S14 sr20det motorset - built head + goodies
Hi everyone, I am selling my s14 Sr20det setup. I bought the car three years ago from another zilvia member who had taken great care of the car. here is the thread #/f/cars-sale/166695...-ac-socal.html
Since then I have had the car a little over 3 years and have barely put 8k on it. I work a quarter mile away from home and it was garaged for a duration of time while I was funding the head build and tune so i didnt put very many miles on it. I always used synthetic and it was never tracked or launched or drifted. The tune was done by steve shadows which will be loaded on the haltech included in the setup. the car made 350rwhp/315 rwtq on pump 91 at 1 bar of boost at 6800 and the power was still climbing but the gas tank was almost empty and there wasnt enough time to get gas and get it strapped back on. You can ask Steve himself that this thing made awesome power. Go to the Shadowerks page and you can see my car with the dyno sheet. The only reason I am selling it is to go LS1. Since the Head was rebuilt, the car maybe saw another 800 miles before i bought a new car and garaged it. I am asking $6000 for the whole thing including the motorset, turbo setup, wiring harness, stand alone, alternator, power steering, ignitor chip, trans etc. FMIC, Radiator/clutch fan sold seperately. More Random s14 stuff at the bottom with prices also. I am not looking to part this out at this point. This is not my DD and its been garaged since march when I bought my new car so im not in a rush to sell. Im located in Rancho Cucamonga, CA. Pick up only on all items. I might decide to ship if stuff is not selling but again I am in no rush.
Stock Bottom End Used mobil 1 synthetic 10-40 its whole stay in america.
The Head
Hand ported and assembled 5 angle valve job by Roy Henderson in the High Desert. He does a ton of domestics and imports and makes heads flow big numbers. I have pictures of the port work and combustion chambers upon request.
Brian Crower 264/264 stage 2 cams (kept vtc)
Brian Crower Stainless Valves
Brian Crower Titanium Retainers
Brian Crower Springs
Supertech valve guides
Circuit Sports Rocker Arm Stoppers
OEM valve locks and seals
Cosworth 1.1mm headgasket
ARP Head Studs
I have the entire nissan oem gasket kit with whats left over from the head rebuild that will be included.
Turbo Setup
GT2871R .86 ar barely seen maybe 1000 miles tops
taka steel braided lines
T-pros tubular manifold ceramic coated by Mike at Young Guns, awesome dude
Circuit Sports Stainless elbow also ceramic coated at Young Guns
intake pipe welded at G-dimension with a K&N filter.
Fuel/Electronics
wiring harness done by phase2, s14-s14 harness.
HKS 740cc injectors (less than 800 miles on them)
Circuit sports fpr
Haltech E8 with a Steve Shadows dynotune, S14 PNP harness with sensors
Gizzmo IBC-R boost controller with rpm dependant boost control
Drivetrain
s14 trans. The set will also come with an ACT six puck sprung clutch, Fidanza 10 lb flywheel and nismo slave with less than 5k miles on them. Also a circuit sports V2 solid shifter thats brand new not on the trans.
Oil cooler and oil filter relocation kit with steel braided lines
EVERYTHING IS PUT TOGETHER JUST DROP THE MOTOR AND TRANS AND WIRE EVERYTHING UP.
Extras
Stock s14 se cloth seats - 200
s14 Ball Bearing T28 - 300
Stock s14 Radiator with hoses and fan - 150
FMIC with SSQV - 250
Stock s14 ecu - 150
Complete Sr20det A/C with new lines (longer to avoid heat from the turbo) - 200
Megan Gauges... Boost, AFR, Oil temp - 40 bucks a piece.
AEM Uego with less than 800 miles - 150
Stock s14 cams - 100
Stock s14 Injectors - 100
s14 driveshaft made for VLSD - 80
s14 Sr20det MAF - SOLD
s14 steering wheel with air bag - 90
I also have all of the seatbelts and plastic panels - make me a reasonable offer.
Everything is pick up only and prices are firm. PM me or email me and we can work out a time for pick up. I work monday-friday 8am-5pm and i have school 6pm-10pm mondays and wednesdays. I have pictures of every item listed for sale and every receipt for every part.
For pictures and questions email me at [email protected]
Thanks for looking!
1992 s13 hatch sr20det RIP 7-7-06
1996 s14 se sr20det
shibbyRPS13 is offline   Reply With Quote
Old 09-30-2011, 11:21 AM   #2
Brodiemans
Brodiemans is on the path to ruinBrodiemans is on the path to ruin
Plus 1 for the seller, I helped assemble the head, motor runs super strong
Brodiemans is offline   Reply With Quote
Old 10-01-2011, 12:57 PM   #3
shibbyRPS13
Saturday bump. 2/3's the cost to build it yourself this way. Some one give this setup a new home.
1996 s14 se sr20det
Old 10-03-2011, 01:23 PM   #4
shibbyRPS13
Last bump I'll throw the radiator setup with clutch fan and the fmic with ssqv with the setup if someone picks it up for 6k. Fmic comes tapped for the IAT and the boost controller. I also have a pending buyer on the haltech so if I can get buyers for the head and the turbo setup, I'd be willing to part out everything.. But only until those have serious buyers. Shipping might also be an option at buyers expense.
1996 s14 se sr20det
Old 10-03-2011, 04:35 PM   #5
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
I am interested in the Gizzmo boost controller as long as it is the one that will support 50psi of boost. let me know
Sr22 in the works
slow92 is offline   Reply With Quote
Old 10-03-2011, 06:55 PM   #6
shibbyRPS13
Pm'd. Looks like the setup is getting parted out. The head will be sold assembled with cams, gears, and valve cover. The turbo setup will be sold with the turbo, lines, manifold and elbow.. Everything else is first come first serve. Pm me or email me for prices
1996 s14 se sr20det
Old 10-04-2011, 11:16 PM   #7
shibbyRPS13
Haltech is back up for sale. E8 with the zenki s14 sr20det patch loom, IAT, and map sensor.
1996 s14 se sr20det
Old 10-05-2011, 08:17 AM   #8
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
price for the oil cooler, lines, filter relocate and block adapter?
Seraphim38 is offline   Reply With Quote
Old 10-05-2011, 08:25 AM   #9
slide101
slide101's Avatar
slide101 is an unknown quantity at this point
Send a message via AIM to slide101
How much for just the driver and passenger belts?
slide101 is offline   Reply With Quote
Old 10-05-2011, 03:06 PM   #10
shibbyRPS13
Too many people backing out of the sales last minute so I'm not wasting my time on people who can't afford it. The setup will be sold as a whole again the way it was originally posted. Fmic and seats have a potential buyer but I'll go first come first serve on all of the stuff under extras. Setup is priced at $6k obo. The stuff in extras won't get parted out and will be sold as they are listed (ac as a whole, radiator with the fan/shroud and hoses). I will make an exception with the fmic and bov though. The bov is tempting to put on my wrx.
1996 s14 se sr20det
built, gt2871r, motorset, s14, seats
