#391 | |
So my Cig Lighter isnt working.. My cluster is so dim..The brightness control dosent function.. im guessing i might replace some fuses.. My cluster works just that the hud is so dim!! any help on the brightness control?? as i will be going over the manual |
#392 |
![]() Join Date: Oct 2007
i have a few. the car i want to get has no windshild wiper lever, but the motor works. how much would the cost of this be and how long would it take?
and also it needs a pcv pipe replacement and o2 sensor replacement. how much would that cost with labor?
#393 |
![]() Join Date: Feb 2008
I got one, Im looking into buying 17x9 +15 rims and I got AGXs and lowering springs. Will I have fitment trouble with the stock "shaped" strut hitting the rim in the fronts? I figured that i can always get the fender rolled since they would stick out. Also the same question for the rear, they are going to be 17x10 +12.
SPENCER DOUGHERTY RIP ME OFF. SEARCH HIS REVIEW THREAD. |
#396 |
what does burnt clutch smell like? (i smell burnt wire around front right engine bay area)where would the smell resonate from? under hood or under car?
#397 | |
![]() Join Date: Dec 2008
Trader Rating: (35)
![]() Feedback Score: 35 reviews
i believe 17m, not sure though
now my questions: 1) whats that tool to pull out the pilot bearing called? 2)anybody have one that i may borrow? 3)engine and tranny got a little wet in the rain, should i worry?
![]() -Jorge |
#398 | |
![]() Join Date: May 2004
Trader Rating: (26)
2. buy at kragen, use, clean, return (what i did) 3. out of the car? were all the 'holes' plugged and sealed? totally exposed in the rain? |
#399 | |
Trader Rating: (35)
haha thanks not total exposure it was wrapped pretty good, but when i unwrapped it this morning it was wet..out of the car and everything is sealed up except throttle body, rad hoses, and ...thats it hehe
![]() -Jorge |
#400 | |
![]() Join Date: Jun 2007
#401 |
![]() Join Date: Oct 2005
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
NO. Do NOT get a pilot bearing puller. You'll be at it for days.
Get a BLIND HOLE PULLER. And the slide hammer of course. With a blind hole puller, it should come out within the first 5 tries.
www.realize-jp.net |
#402 |
i wrecked my car the other day, and since then when i hit a bump the ass end seems to sway. what could that be? FYI, i jumped a ditch and hit a tree.
#404 |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() Feedback Score: 20 reviews
have you checked your alignment since the wreck?
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
#405 |
yea i looked, nothing seems broken, and the alignment is straight. idk, maybe some bushings are just worn and i haven't noticed it until now. i need to replace the suspension parts and subframe bushing, maybe that is what it is
#406 | |
have you actually gotten an alignment? it might be worth the money. just because it looks straight and drives straight doesn't mean it is.
BRICKHOUSE PRODUCTS
#407 |
#408 |
#409 | |
#410 |
Does anyone know of a good product to shine up weather stripping?(Plastic Moulding around the windows, looks smoky gray) Tire shine will collect dust and I've read that some products need to be re-applied several times a month and/or will run leaving streaks. Just wondering if anyone has used something that were happy with. Thanks!
#412 |
Lame question
I know the boot is ripped, but should oil be coming out? Would a new boot solve the problem or is there a part missing in the tyranny to seal it?? |
#413 |
![]() Join Date: Sep 2009
im trying to convert my car to 5 lug so i gota question 4 u ..
i gota 95 s14 how do i know which rotors to buy? abs or non-abs ?
alpha kenny body. |
#414 |
#415 | |
1. broken rear sway bar end links. 2. alignment is off 3. driver side suspension is blown.
Find me on MR2oc! |
#417 | |
Back to black by mothers(in a red bottle)
needs very little product, but lots of rubbing. Difficult to get off paint(oily). May need 2-3 applications, heavy application does not help. Quote:
#418 | ||||||
Blow me, bitches.
#419 |
Anybody have an OEM part number for the little white plastic clips/separators that hold the brake lines in place on an S13?
I don't really feel like fabbing my own, but the old ones are so brittle, they crack like glass.
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please. |
#420 | |
This one? Nissan OEM Brake/Fuel Line Clip - Dual Pipe - Nissan performance parts
Blow me, bitches.
| 180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
