Brake Tune-up
Hey guys, my front brakes are shot to crap on my s13 and so is my passenger ball joint. I'm on a restrictive budget, but I think I've finally put together the parts I'm going to get. Before I buy them, can I get some feedback to determine if this is the right route and worth the upgrade?
RAYBESTOS 507-1311 Control Arm/Ball Joint Assy | eBay Centric Parts 105.07000 Front Original Equipment Ceramic Pads | eBay Centric Parts 121.42041 Front Disc Brake Rotor | eBay My concern with the rotors, is that it does not specify if it's for ABS or not. How do I tell? I do not have ABS. As for the pads, I don't believe it comes with shims and I cannot find the kit it requires. Does it actually come with shims or should I avoid these for that reason? If you were going to do this, would you recommend different parts? I would like to end up paying no more than $150 for everything. Thanks for reading.
1991 240sx Hatch Daily'd! |
Autozone for pads / rotors.
Duralast/Brake Rotor - Front (3215) | 1991 Nissan/Datsun 240SX 4 Cylinders M 2.4L SFI DOHC | AutoZone.com Duralast/Brake Pads - Front (MKD422) | 1991 Nissan/Datsun 240SX 4 Cylinders M 2.4L SFI DOHC | AutoZone.com pdm-racing.com for the control arms. PDM Racing - Specials
![]() Join Date: Apr 2008
Go to advanceautoparts.com
I just added all your items and entered the coupon code:MA30. It came out to 125.83. You also get a $50 coupon towards your next purchase of $100 or more. Order the parts online and then pick them up at the store. |
I can't afford $200 for the AutoZone and the nice control arms. I was looking at the specific setup because I know Centric makes StopTech and PowerSlot, so they must be of good quality. The Rotors are unbeatably priced and I was aiming for ceramic pads. As for the LCA, I know Raybestos is good stuff. So my picks were really that bad you guys would recommend FailZone items over it?
The rotors you chose are actually the ABS rotors. If you note, ABS rotors have a thickness of 22mm and non-ABS have a thickness of 19.89mm or ~20mm.
#6 | |
As for the ABS thickness, that is something I was not aware of. Truly appreciate the information, I'll look for non-ABS rotors ![]() EDIT: I found these on eBay and I've been researching them. Everyone seems happy with them. Any opinions? http://www.ebay.com/itm/FRONT-REAR-K...ht_6325wt_1396
1991 240sx Hatch Daily'd! Last edited by RandallSharp; 03-15-2012 at 03:38 PM.. |
