1989 KA24DET 240sx Drift Missile
Hey everybody! Haven't been on Zilvia for a while. The last time I was on here was almost three years ago when my car was stripped and stolen. It took me a while but I've rebuilt it since. Now times are tough for me and I'm going to have let go of my baby.
![]() $3500 (negotiable) Please text 6266074451 for more info. Engine and Trans: Rebuilt KA24DET motor for turbo with cams and low comp pistons ARP head studs Cometic MLS head gasket 550cc injectors from Mazda FD3S XTD Stage 2 clutch with aluminum flywheel Stock T25 turbo off SR20det with Z32 maf CX Racing exhuast manifold Megan Racing turbo outlet and downpipe RS Type 2.5" catback exhuast NRG spark plug wire set Godspeed intercooler and aluminum radiator Godspeed catch can and overflow tank No-brand dual electric fans Godspeed manual boost controller No-brand FPR Interior: NX1600 digital cluster Apexi SAFCII piggyback on KA24DE ecu AEM AFR gauge Megan Racing turbo and water temp gauges 350mm D1-Spec black leather steering wheel NRG Gen 2.0 quick release hub w/ lock Tomei shift knob 2x Sonic Motor P2 bucket seats Sonic Motor harness bar No-brand 5pt racing harness Sony headunit with aux and USB X-Plod 6" front speakers Viper alarm Supsension and Misc: Godspeed Mono-RS coilovers TEIN inner and outer tie-rods Godspeed Gen-2 tension rods Megan Racing rear sway bar Megan Racing RUCAs Megan Racing test fit front and rear strut bars Driveshaft Shop one piece aluminum driveshaft Solid delrin motor mounts Megan Racing poly-urethane transmission mount Poly-urethane exhaust hangers 88 Rotor slotted and drilled brakes Megan Racing BMC heat shield NRG radiator plate VLSD Exterior: 16x8 XXR 002 black spoke chrome-lip wheels (4x114.3) 205/50 Rotalla Radial tires TCSportline OEM style carbon hood w/ pins D-MAX front bumper VIS Racing 25mm wide front fenders Forcewerkz Type-X style side skirts and rear valences Clear turn signal lights (amber bulbs) No-brand rear window visor Cons: As mentioned before, it's a salvage title due to theft. Leaky motor, oil pan has two stripped bolts. Oil line above turbo had burst. Turbo has some play, and needs to be replaced soon. Same with clutch, upon startup it'll slip until warmup, and under boost in 5th gear it will also slip. Wiring is a bit of a mess. Speedometer/odometer and gas gauge does not work. Power steering is there, but it leaks and might add well not work. No AC and windshield wipers don't work. Window seals were stripped as well, and car will experience leaks in rainy weather. There's a little rust in the trunk as a result. CF hood is breaking apart, and the hood pins are also broken. Zip ties are also everywhere. No interior. Could use some body work and a lot of paint. Pros: This car PULLS, and it is a boat load of fun. Car has already been tuned by Garage Life in El Monte, and GL also oversaw some of my work as I rebuilt the car with my own hands. Roughly 280hp to the wheel and a lot of torque. As you'll infer from the list there's a huge amount of parts on the car. Suspension feels solid and reliable, and car handles and turns on a dime. Good car for a drift project and just about everything you need to start is there. I've put in a lot of love and labor so please be kind haha. If this car interests you (and I hope it does) shoot me a text at 6266074451. I'll try and get some better pictures up if I have time. Hope you're all having a great night! - Wilson |
| forsale, ka24det, s13 |
