![]() Join Date: Jul 2007
Trader Rating: (106)
Random S13- markers, vents, radio/din/brackets, alt belt, cone filter w/adapter
2 right side S13 front sidemarker housings
These are 2 right side front sidemarker housings for an S13. Unfortunately I don't have a left side. Both housings are clean, no cracks or fading. I do not have the light sockets for these. $5ea 1 SOLD, 1 left S13 dash vents These are the side vents for an S13 dashboard. Both vents are clean and in good operating condition. I do not have the center vent. $10ea Driver's Side SOLD!!! S13 radio brackets/DIN pocket/Pioneer head unit This is a complete radio setup for an S13. Included are the radio brackets, DIN pocket, and a Pioneer head unit. The head unit is an older model, but has an aux input on the front of it. I will also include the antenna adapter, but I do not have the wiring harness adapter, which can be found at almost any auto parts store for less than $10 out the door. SOLD! Dualcam KA alternator belt This is a BRAND new KADE alternator belt. Never used, in the original packaging. $5 S13 aftermarket air filter W/MAF adapter This is a K&N style oiled air filter with the MAF adapter for ANY S13 with a stock MAF sensor. The filter is pretty dirty and needs to be cleaned and oiled, but is in good shape, no damage. The adapter is good quality cast aluminum and has the port for the air injection, if you wanted to keep that. $30 KA M/T starter bolts This is a pair of mis-matched S13 manual trans starter bolts. The heads of the bolts are different size, but the thread length and pitch are the same and correct for a manual trans KA. $5 S13/14 clutch/brake pedal pins These are the pins that attach the clutch and brake pushrods to the pedals. These are all from the brake pedal originally, but work for either pedal. All 4 pins have the clips with them. $5 each One pin sold, 3 left Last edited by racepar1; 04-15-2015 at 10:45 PM.. |
