Old 09-09-2006, 02:46 PM   #1
shooty
shooty is an unknown quantity at this point
oh boy another tire size question
I'm trying to figure out what tire size to put on my rims
im goin with 17*8+33 all around
my two tire choices are falken rt-615 and hankook r-s2
i realize the offset is not ideal but i will be running konis+springs
im probly goin to get 225.45 or 235.40 size regardless of tire
I know these tires run wide but do you think i can get away with 235s?
anyone running these tires in those sizes with around the same offset on stock suspension or even getting away with it on coilovers?
i believe the 225s are doable but would like conformation
I DONT WANT SPACERS - please dont suggest that
any other input is welcome
thanks
EDIT: forgot to mention that it is on an s13
shooty is offline   Reply With Quote
Old 09-09-2006, 03:02 PM   #2
wwwyzzerr
wwwyzzerr's Avatar
wwwyzzerr is an unknown quantity at this point
ive got 225/45 rt-615s on the fronts with a 28 offset and they are fine for suspension clearence close though but they clear
wwwyzzerr is offline   Reply With Quote
Old 09-09-2006, 03:44 PM   #3
fuzzy_tanit
fuzzy_tanit's Avatar
fuzzy_tanit is an unknown quantity at this point
i run 225/45 245/45 on s13 and i have to roll my fender a bit....but my car has no fender gap..and 2.3 and 2.0 deg of camber...let me know if that help
oh if it dont fit i found out that a BIG hammer is my best friend
fuzzy_tanit is offline   Reply With Quote
Old 09-09-2006, 03:54 PM   #4
shooty
thanx for quick replies
fuzzy, im more concerned about inner clearance - the front strut to be specific.
wwwyzzerr, are you doing this on 17*8's? also what suspension you running? do they look like .5 to 1cm more tire width could be put on the inside?
i know 17*8 need an offset ~<+30 but ive seen some running +35 and clearing 215's or even 225's but im not sure what tires/ suspension they use for it
Old 09-09-2006, 07:52 PM   #5
cgguy
cgguy's Avatar
cgguy is on a distinguished road
I run 225/18's +30 on the front with coilovers and have about a finger width gap of clearance. You should have no problems with 235's and shock/springs.
fyi I've got 255/r18's +33 on the rear, again with coilovers and have pleanty of clearance.
That said I think 225 is the best size for your fronts....235 feels a bit beefy imo.
cgguy is offline   Reply With Quote
