stock tune ecu on a built high compression sr20det
I have a sr20det and I was wondering if i am able to use my stock ecu for the time being and a safc2. Or do i have to so dome tuning to make it drivable. It will run but II have to give it gas or it'll die. Help Pls!!
Mods Hks 272 step 2 Hks valve spring Crower Retainer Top Speed Manifold Cometic 1.1 headgasket 87mm 9.0cr cp piston Eagle Rods Stock 370cc (for now) z32 maf gt2871 .86 Last edited by llteddy4playll; 07-23-2006 at 06:07 AM.. |
What's the point of trying to drive it? The car will feel like total shit with those big cams and I wouldn't boost on the stock ECU and stock injectors. You'll probably do some damage real quick with that setup.
