Custom Gauges
I will be doing a full custom gauge set up. I have all the parts now for the wiring. I have a 1993 240 (With a SR Full AEM set up)
I been trying to fine the pin out on the stock gauge cluster. I have been having no luck I have water, Boost, oil pressure working. So the questions is: Where can i find the pin out for tachometer and fuel gauge? Thank you. |
#2 | |
![]() Join Date: Jun 2009
Also, the back of the cluster has everything labeled on the circuit sheet... ![]() Sent from my SM-G935T using Tapatalk
Contributions: ULTIMATE climate HVAC LED conversion. |
#4 | |
#6 | |
Here's the cluster I've been working on. The gauges are easy to wire. What's harder is the things that need resistors. If you're using the factory cluster, you don't have to worry about any of those things.
