![]() Join Date: Aug 2017
5 speed swap reverse light wiring
Finally finished up the 5 speed swap on my s13. Wired what I thought to be the reverse light wires up and no luck. Which wires are the wires that need to be wired up to the reverse switch?
![]() Join Date: Apr 2017
I've never done it, bought mine as a manual, but these should get you on your way.
http://nicoclub.com/archives/240sx-m...-tutorial.html http://nicoclub.com/archives/automat...nual-swap.html
¯\_(ツ)_/¯
took me less than a minute to wire up the switch, and about 15 min of trouble shooting to find out I had it all right from the start... I had it wired up correctly and it was all ready to go. My problem was the brand new switch I picked up, wasn’t working. Kinda figured I’d be better off just replacing the switch since it was so cheap but I guess if it ain’t broke don’t fix it. Tested my old switch and it works fine so gonna be installing that and I’m good to go.
