Old 07-27-2013, 02:00 PM   #1
joshfng
joshfng is an unknown quantity at this point
First 240! My sr20det s13 coupe build.
New to 240's but not new to tuning and wrenching on cars. Just picked this up already swapped with a sr20det blacktop and some mods.
sr20det
isis rs turbo @ 12psi
hks ssq bov
fmic
3 inch dump tube and exhaust
kyb agx adjustable shocks/struts
cx racing alum radiator w/ electric fans
unknown stage 3 clutch (according to previous owner)
Now some pics! It's spray bombed right now (yuck) but that'll change soon. There's a ton of rust underneath which I know is common. Some spots have already been patched (badly) but there's a lot to fix under the car and on the frames.
Had horrible stickers on it when I got it (adhesive still there in these pics)
Had some sort of alcohol/meth cool mist injection hooked up the the charge piping pre-throttlebody (I yanked it, didn't work)
Yanked everything not needed
Digital speedo was broke so I swapped an analog cluster in
Found a boost leak!
Started cleaning the rims and realized they were plasti-dipped black.
Replaced the valve cover gasket
How it sits now
And some fun after I got it (need a welded diff!)
joshfng is offline   Reply With Quote
