Old 08-21-2008, 02:18 PM   #1
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
starting issues help me out
hey guys just hoping i can get a clue as to whats going on.
The starter in my ca18det went out so i for a new one from a fellow zilvian and what do you know the car starts up. The thing is after one start it would not start. I made sure my battery was good and even bought a new one and now its weird because it will start sometimes and other times nothing. The alternator is charging the battery also, what do you guys think just some loose/bad wiring
jorge1190 is offline   Reply With Quote
Old 08-21-2008, 02:39 PM   #2
twastheglow
twastheglow's Avatar
twastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nice
Send a message via AIM to twastheglow
Bad wiring could do it. I know with most starters, if they're failing, you can hit them with a hammer if it's not cranking and it'll work. That just means you're going to need a new one very soon.
Maybe the one you got is on it's way out. That's not to say the person who sold it to you knew. They probably didn't. Anything's possible.
*mike*
twastheglow is offline   Reply With Quote
Old 08-21-2008, 02:45 PM   #3
jorge1190
thanks for responding...anyone else?
Old 08-21-2008, 04:20 PM   #4
!Zar!
!Zar!'s Avatar
Starter relay.
It is a blue relay between the stock battery location and the fender.
Check and replace it.
Old 08-21-2008, 08:29 PM   #5
jorge1190
thanks that deffinitely had not crossed my mind
Old 08-21-2008, 08:49 PM   #6
DRFTSAINT
DRFTSAINT's Avatar
DRFTSAINT is on the path to ruinDRFTSAINT is on the path to ruinDRFTSAINT is on the path to ruin
Double check that all the connectors to the starter itself are clean and firmly attached. My SR was having the same problem, and I finally checked the wire that bolts from starter to the solenoid and it was filthy, I cleaned all the contacts and it works fine now.
Corrosion happens in places you least suspect.
Hope that helps
DRFTSAINT is offline   Reply With Quote
Old 08-21-2008, 09:16 PM   #7
jorge1190
i guess tomorrow ill pull the starter off and clean everything up as well as clean up some grounds thanks also
Old 08-22-2008, 03:10 PM   #8
jorge1190
bump any ideas before i dig through connections tomorrow
Old 08-22-2008, 04:57 PM   #9
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
starter relay
maybe clutch interlock relay?
JRas is offline   Reply With Quote
Old 08-22-2008, 10:06 PM   #10
jorge1190
the car used to be an automatic and the clutch switch was never wired up
Old 08-23-2008, 12:59 AM   #11
!Zar!
!Zar!'s Avatar
Did you check the starter relay?
Unplug the big blue relay between the stock battery location and the fender.
Then jump the connector with the thicker wires with eachother; so pretty much make a, "U" with a paperclip.
After that, try to start it.
