![]() Join Date: Aug 2006
S14 Crankcase hose//vaccuum leak problem.
![]() As you can see by the pic, I have a hose going from the driver side. It is basically blocked off, or broken and now open. The hose basically goes NO WHERE!?!? just wondering how I should fix this? Usually i believe this hose goes back to the rubber/plastic intake. Should I T it off to the rear hose or get a Catch can? BTW: the hose look gray in the picture.
1995 S14 NonSunroof. |
