Closed Thread
Old 07-02-2003, 10:09 PM   #1
Red
Red's Avatar
Red is an unknown quantity at this point
Electric Turbo? I decided to see if it works (Work in progress)
Alright I know alot of people say this does not do anything and will fuk up your car... But I just used (MSM money) and found I spend 500$ a month on food... So I switched to top romen and decided to take on the quest to try out this "Electric Turbo"
This is the 1st in quite a bit of work. Its going to take me a little while becus I'm a puss when it comes to hacking on my car.. I only have 1
I have purchased 2 bilge pump fans from a boat store... they are 4" 12volt 4.5amp fans that push 240cfm's of air.
I have also gone to home depo and purchased quite a few 4" pvc bends and 3" bends... along with a 4" to 3" reducer... I'm not quite sure how the pvc will hold up to the engine heat... I'll deal with that later.
I have an Automete A/F and Volt gaudge on the way.. yeah thats guna be fun install (not) I have not desided where to mount them as of yet... But am leaning to the 3 DIN pod... (Guna make it out of lexan)... I was also thinking of buying an Intake temp gaudge... But I'm not to fond of spending all my new found cash all at once.
Before you all rip me a new one... here is my hole..... in the car.
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
#/f/showthread.php?t=21036
Red is offline
Old 07-03-2003, 12:47 AM   #2
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
your probably the only one on this board to try this...
and i admit the concept of the electric turbocharger is dumb..
but i respect you for having the b*lls to try..more upsw to you
keep us updated..
s13silady is offline
Old 07-03-2003, 01:28 AM   #3
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
okay, I know I said it in the other thread about your gauges, but I'm going to say it again.
RETURN THE AUTOMETER A/F GAUGE!
Biggest waste of $ EVER.
www.360realms.com/S13-S15
Yoshi is offline
Old 07-03-2003, 01:41 AM   #4
Sundi240
Sundi240 is an unknown quantity at this point
Man you could probably smoke some Mustangs after installing that mofo!
Sundi240 is offline
Old 07-03-2003, 02:19 AM   #5
Anubis
Anubis's Avatar
Anubis is an unknown quantity at this point
Send a message via AIM to Anubis
I made this cool intake from an old bucket. It rocked, better then any turbo or supercharger.
Anubis is offline
Old 07-03-2003, 10:35 AM   #6
Red
Red's Avatar
I'll look into another one... or an EGT... How do you read an EGT?
Red is offline
Old 07-03-2003, 11:58 AM   #7
Yoshi
Yoshi's Avatar
Actually, you should use the A/F gauge and EGT gauges in conjunction to help tune and troubleshoot, the kinda work together (FPR and fuel pressure gauge too).
EGT's are something I haven't done yet (but plan to), AFAIK you drill into your exhaust system and install a temp sensor, then learn at what point your temp should be and when.
Yoshi is offline
Old 07-04-2003, 11:25 AM   #8
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
you realize that those fans blow 240 unrestricted cfm. thats not 240 cfm into a pressurized manifold. and 2 of them does not equal 480 cfm. you realize a turbo is built to spin at over 100,000 rpm?
those little fans you got there might spin at 5,000 rpm. this won't fubar your engine, but they will restrict air going into the intake. Have fun wasting your money. There's a reason no one does this that knows anything about cars.
sykikchimp is offline
Old 07-04-2003, 12:14 PM   #9
weirdstyles.net
This guy...
weirdstyles.net's Avatar
weirdstyles.net is an unknown quantity at this point
Send a message via AIM to weirdstyles.net
I comend you on your trials, but we both know it will most likely lead to crap. I applaude your initiative, its how most great inventions get invented. Please, however, don't send another penny to hell with this project. Save up and build the first KA24DETT, where we will all gawk and praise you for your efforst...
or buy a n1 dual and call it a day...
My project car...
From dust you were born,
And to the ashes you return ~ Kill Switch Engage
Family Guy
Quagmire: Hey, how old are you sweet thang?
Connie: 16.
Quagmire: 18? Alllll-right!
Connie: Mommmm!
Quagmire: I like where this is going, Giggidy giggidy gig-gi-dy!
weirdstyles.net is offline
Old 07-04-2003, 04:47 PM   #10
chairmnofthboard
chairmnofthboard is an unknown quantity at this point
do it
try it, you already spent the money & cut the hole, might aswell try it. i think your going to need a blow-off valve and a full throtle switch.
full throttle to turn the fans on at WOT
blow-off to let the air out.
try it with just the full throttle switch first, that might be enough, and you'll save money too, the switch is like $10.00
chairmnofthboard is offline
Old 07-04-2003, 05:11 PM   #11
Bill Roberts
Bill Roberts is an unknown quantity at this point
Sorry to say...and I posted this before...
It is most amazing how much air is going through the intake at WOT. The fans will drag. Their is a certain power band they =could= work but damn, the ecu will go nuts trying to figure it all out.
I would fear for the fans being sucked into the engine. Have you ever put your hand over the exhaust pipes at WOT? At least that much air is going in.
In the very old days, my Dad (he is 80years old now) installed, what was called a "electric superchargers" on his 37 Plymouth coupe. It had a knob so you could turn them up as you accelerated. They were HUGE devices...blowing 1300CFM MAX into the engine which was a strait 8. Took two batteries to run them for a few mins. All cars were 6 volts then. He slung the tops off the pistons and ruined the engine. The old man ran a measured mile at 126MPH in 1947 with it though.
BTW, He was also a test pilot..
Bill Roberts is offline
Old 07-04-2003, 09:12 PM   #12
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
Woah, thats pretty cool. What planes did you dad test? You got some cool roots.
RedlineRacer is offline
Old 07-05-2003, 01:47 PM   #13
Red
Red's Avatar
Yeah yeah yeah....
sykikchimp - Yes I understand how the fans work... And that they wont push as much air as my engine needs at WOT. But they should help up to 4000 somthing RPM's..... More air = more power.
I have been thinking of ways to make them not restrict my air flow... but still add air.
About the foot switch... I have found RPM actavated switches... Also autometer makes a 12volt 10amp rpm **** lite switch that runs off there tac...
(Anyways... Just remember I dont know this is guna work... I know it sould help and i'm willing to find out what will happen.)
Red is offline
Old 07-06-2003, 02:43 PM   #14
Bill Roberts
Hey Redline racer!
Pop flew everything he could get his hands on. This was in 43/44/45. He flew Captured Mitsubishi zeros, ME109's, P51's, P38's, the list continues forever.
His favorite plane is the P38 lightning. The P51 runs a close second. He really likes WWI aircraft as well.
His official duty was to report maximum safe specification of the aircraft. This meant taking them beyond their limits. He would try to "tear the wings off of them" and had to bail out of a few that became overstressed. He was an officer for the Army air corps...before the branch USAF exsisted. He logged thousands of hours in the 3 year period. He even flew the P59 comet (our first jet) and did some harrowing stunts that I feel would be best not talked about. He could not get it out of his sytem and began designing and building model airplanes (I love this hobby) and aquired a large field which to fly them...which we now share and I have aquired it myself.
Yep, the Old Man is amazing. He still flys too. He got a ticket doing 84 in a 70 a few months back..
Old 07-06-2003, 08:53 PM   #15
Toahk
Toahk's Avatar
Toahk is an unknown quantity at this point
Send a message via AIM to Toahk
be sure to get some type of mesh or something in front of the fans incase something decides to come off of them, wouldnt want a chuck of metal/plastic/etc flying into your engine now.
Toahk is offline
Old 07-06-2003, 10:32 PM   #16
Red
Red's Avatar
There is already a strong mesh screen infront of the MAFS... I whacked it a few times with my finger... Somthing would have to hit it very hard to go through.
I'm still working on cutting the hole... I needa barrow my friends roto,tool to finish the hole... And i'm working on a custome dash thing... Around the radio...
I was lazy this weekend with the 4th and all the family...
Red is offline
Old 07-07-2003, 08:29 PM   #17
krazy_racer
krazy_racer is an unknown quantity at this point
Send a message via AIM to krazy_racer
just use that money to finish paying off the car instead of fuccin with it.
240sx
krazy_racer is offline
Old 07-07-2003, 10:18 PM   #18
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
sweet that looks almost like my speed hole!!!! haha
anyway, got another idea for ya if the fans are too restrictive. try mounting them in your speed hole area to try and drive more cool air into the intake area. and dont forget to try and block off the cone filter from the rest of the engine bay (where more hot air dwels) with sheet metal and use rubber hose (like fuel lines) to put around the metal edges so it doesnt look like crap.
ill try to post pics of my custom set-up when its light out...
-glen
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline
Old 07-07-2003, 10:29 PM   #19
AKADriver
AKADriver's Avatar
AKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura about
Re: Yeah yeah yeah....
They won't even push as much air as your engine needs at IDLE.
An average sized supercharger takes 20hp or more to spin and compress air.
The electric motors on those pumps combined are making about 0.1hp...
AKADriver is offline
Old 07-08-2003, 10:37 AM   #20
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
Hey Bill, tell your Dad he shouldnt go out past 10PM on Saturdays.
I knew it, he's a party animal deep down inside. he he he!
- Mike
old_s13 is offline
Old 07-08-2003, 10:40 AM   #21
old_s13
old_s13's Avatar
yes, and we need to borrow a gun to put you and your electric-fan-super-turbo-charger concept 6-feet under.
(sigh)
Dont any of you remember on the old AMAROK list when we did something like this? I cant remember exactly who it was, but I remember they strapped a lawn-blower onto their intake..
but gee, back then that was done for COMIC RELIEF.. I guess some people think they can reinvent things!
old_s13 is offline
Old 07-08-2003, 05:24 PM   #22
Red
Red's Avatar
old_s13 That was a totally uncalled for asinine remark that I would like you to refrain from doing in the future… I don’t care if you want to flame me… Or give me reasons you don’t think it will work… But saying I need to be killed, well that’s just retarded.
Crioten I was looking into mounting the air filter in the Speed hole spot… Right by the fog light is where you were thinking right? It would be easy to mount one fan down there… But 2 is going to be a challenge… But that’s ½ the fun.
Btw just an update for any who care…
I got the lexan cut to size to mount in my DIN slot. I am going to purchase a 2” hole saw tonight on the way home and put it on my drill press… I should have at least one gauge all wired up tonight… maybe both not sure. I’ll wire the fans power tonight as well depending on how time will permit (I do need to log on and play Star wars galaxies tonight) But I will try to get this done 1st.
I still don’t have the damn rotor tool… Harbor freight has a cheep one for 20$ I’m going to have to go buy, or I’ll never get that hole done.
Once the hole is cut I need to go to Auto Zone and get a MAFS Adapter… well 2 of them.
So that’s what’s going on.
SHIFT_flame! <-- I am so guna trade mark this one!
Red is offline
Old 07-08-2003, 11:56 PM   #23
crioten
"buddy jesus"
crioten's Avatar
i thought about doing mine that way...but decided to not play with too much hose.
the next thing im going to do is make a steel shaft/duck thingy that goes back from the foglight/ vent thing up to the speed hole (instead of putting the actual filter down in there)
im doing this b/c it would be a pain to do, could suck up water, and would be another pain to change/replace the filter...im sure you know this, but be sure that the inside of all the tubing is smooth and such so that it wont mess up your mafs, and make your car run funny.
does your car have a foglight or the vent? if it has a foglight, you could also make a small inlet on/near the radiator area to suck in more area.
but do whatever ya want to, its your plan hope it works out for ya...
crioten is offline
Old 07-09-2003, 09:31 AM   #24
Red
Red's Avatar
My car does have the fog lights... I think its a fist size opening next to the fog light... Never tried fisting it tho. (lol)
I'll see what I can fit down there. This 4" tubeing is a pain.
Anyways.
That lexan is super tuff I got my 3 holes cut with the 2" hole saw. But I had to put a 2" sanding bit on my press and sand the hole bigger, which took a while. It diddent help that I got home late from work. Man I hate traffic!
So I diddent get any wireing done
Now that I have my gauge face done I can mount it in my dash. Should look nice... One of the holes is a bit left... But I dont think you can tell with the gauges in.
Does anyone have a good 95 240sx ECU chart? I saw the one on www.240sx.org but I want another to compair... I got a lame chilton book and I cant find the ECU wire in there.
I would take more Pics... But that camera eats AA's and my bro lost the recharge cord so I needa go get a new one.
Red is offline
Old 07-13-2003, 04:33 PM   #25
Red
Red's Avatar
Ok people. A little update on this real quick...
I got my Autometer installd... And don't pitch me crap about the A/F it works fine... I duno wen't wrong with yours but mine works like it said it would... It jumps around like all hell and works best at WOT... kool with me.... anyways here are some pics... Give you your feedback. yeah yeah there is a big hole.
Red is offline
Old 07-13-2003, 04:34 PM   #26
Red
Red's Avatar
another kinda better shot
Red is offline
Old 07-15-2003, 08:56 PM   #27
old_s13
old_s13's Avatar
Why does this thread exist?
old_s13 is offline
Old 07-15-2003, 11:19 PM   #28
Red
Red's Avatar
To make you mad!
And
Becus I wated to do somthing other then just guess how this **** works.
Maby if more people did this less people would guess and know wtf was up... Or we could all just keep tossing out our .02 cents... but thats not worth much.
Next time you bring this up from the second page have somthing worth reading... Mmmmmk? :hammer:
Once I get done and i'll post more.
To make you mad!
EDIT: Maby we should rename this to. Electric fan assisted intake?
Red is offline
Old 07-16-2003, 11:38 AM   #29
Thurazor
Thurazor's Avatar
Thurazor is an unknown quantity at this point
Send a message via AIM to Thurazor
It'll be interesting to see how it turns out. I'm very pessimistic about the results, but atleast you're giving it a shot and doing it instead of just complaining. Good luck.
- Jared Edwards
3S Hybrid
[img]too.big.jpg[/img]
&quot;Mandies, sandies, peppermint candies, we do it right and we drink a lot of antifreeze.&quot; - Group X
Thurazor is offline
Old 07-16-2003, 02:04 PM   #30
sykikchimp
WOW addicted
sykikchimp's Avatar
we aren't guessing. It's not going to work. this isn't rocket science.
everyone has to learn the hardway sometimes.
Closed Thread
