Camber correction on s14
What parts do I really need in order to fix camber? Im confused on which parts to buy when I see upper & lower camber arms for front and rears??
I used to have a g35 and it was just the upper arms in the front and bottom arms for rears. Please, can someone explain the purpose for having two camber arms infront and rear on the s14? |
Man w/ CTSV & a Car Seat
S-chassis only have 1 set of camber arm. Depending on how low the car is, you'd probably need a toe arm in the rear too (for slammed cars). Front camber can't be fix by any aftermarket arms, other than a coilover with camber plates on it, you're only other option are eccentric bolts (stock setup) and slotting the shock mounting holes.
