![]() Join Date: Dec 2008
Trader Rating: (50)
![]() Feedback Score: 50 reviews
help s14 caliper on s13/ e-brake ???
ok so the ebrake cable dont hook up cuz its a bit diff
any ideas on wat i can do ? im on prosses or working on it right now so advice please thanks
....that what she said
![]() Join Date: May 2004
Trader Rating: (26)
I can't say for certain which part.
Another thing, make sure your putting the correct caliper on the correct side. The bleeder valve should be pointing up and at its highest. R = passenger side L = driver side |
Trader Rating: (50)
yea i got the right one but wat part do i swap?
the part were u hook up the e break cable to the coil or spring on caliper is diff it dont go on right
![]() Join Date: Sep 2005
You want to use the s14 calipers with s13 cable right?
If so, use the s14 calipers, with s13 cable support and s13 barrel lever, instead of s14 hook lever and s14 cable support
#9 | |
Trader Rating: (50)
#11 | |
Trader Rating: (50)
Sorry about that. I was pretty sure I used the s13 cable support and lever maybe not, it's been a few years since. I do know it worked great!
#14 | |
Trader Rating: (50)
all good here thnx for the help guys ![]()
