Car wont start.
i have a 93 240sx with an s14 sr20det in it. came out of work today, went to start the car, it started fine. ran for like 8 seconds then shut off and wouldnt start again, fans wont turn on, all other electronics work. Its turning over so its not the starter. hooked up the jumper cables to my brothers car just incase the battery was alittle low, still didn't start. fans still wont turn on. my car is stuck at work.
fuel pump fuse? my friend had the same problem, turns out his wires on the pump were touching somehow, id pull the pump out and make sure the wires in there are good.
Tags |
help 240sx, luke pfleiderer, sr20det, start up |
