Motor/tranny; blacktop sr20det s15 T28 s14 waterneck stainles steel braided lines turbo oli/water greddy catch tank, stock manifold, s15 manifold gasket, custom wategate, new starter, new oem alternator(retail 849.00) new water pump, motor was all regasketed execpt for head. Blitz spec r boost controller, custom valve cover painted black and shaved, new plugs, all new power enterprises belts, new clutchfan, new fanshroud, aftermarket intrcooler, and radiator, nismo motor/tranny mounts, silvia crossmember, act stage 3 clutch light weight flywheel(clutch needs to be replaced sticking) original c's shrot throw shifter.
Drive train/suspension; apex n1 ex-v coilovers, nismo powerbrace, stk tension rods, tein tierods, new lca's with nismo boots, skyline differential with corresponding axles.
Brakes. Z32 aluminum calipers stainless steal braided lines all the way around, ichiba hubs with 2k miles, slotted rotors, tokico z32 master cylinder, ebrake is fuctional 2+2 cables with custom brackets, R32 gts-t rims with sumitomo tr4 tires 3k miles also have set of z32 tt rims rear two match front two na rims.
Interior; mint condition s14 seats, headliner was redone, most interior pieces are there, havepower window setup door panels glass, rails sliders motors, and switches, dash is cracked has hud, jdm manual seatbelts.
Probably left stuff out, hit me up for info
[email protected] or 9098152311 for quickest response. Thanks!
