Old 01-02-2015, 11:28 PM   #31
S14DB
AFC #1
S14DB's Avatar
Originally Posted by jliehr View Post
Yes. But I like to own the tools I use rather then rent them. 9 times out of 10 you are going to need that tool several times and its much nicer to have immediate access to that tool. When I get some money I will send out some oil, just a tad low on funds right now to send that out. Unfortunately I do not have an oil pressure gauge as well. That is something I will look into picking up as it is another great thing to have.
Thank you for your help .
Hell the Harbor freight compression tester works as well as he AZ one. But, if you are low on funds the rental from the parts store is free.
Old 01-02-2015, 11:29 PM   #32
jliehr
jliehr is an unknown quantity at this point
I thought they make you pay for the value of the tool?
jliehr is offline   Reply With Quote
Old 01-02-2015, 11:33 PM   #33
jza80king
jza80king is an unknown quantity at this point
You rent it and they charge you and you get a refund once you return it. I bought both a cylinder leak down and a compression tester from harbor freight, honestly have only used each tool maybe 2 times. Some tools you use more often but unless you are constantly building motors or tearing them apart you won't use these 2 tools all the time.
jza80king is offline   Reply With Quote
Old 01-04-2015, 11:24 AM   #34
littlegabe
littlegabe is an unknown quantity at this point
Looks like you need a new coolant reservoir too, looks a bit corroded, radiator too. 89-90 were the single cam years, then dual cam till 98'. This is a case of false advertisement, and failure to check the vehicle before you bought it.
littlegabe is offline   Reply With Quote
Old 01-04-2015, 06:16 PM   #35
jliehr
Read the thread next time please, thanks.
