S13 SR20 vac line questions
Ok so i've read through a few threads via search and always seem to find mixed answers never anything concrete so please spare me i been searching for a bit.
I have - S13 SR20 (stock intake & TB) - S14 T28 HKS adjustable WG actuator - HKS SSQV bov - Prosport boost gauge So from the info I gathered the left nipple (TB) goes to the FPR, what confuses me is I see some people say NEVER tee off of the FPR to the boost gauge while others say it's fine. second, the right nipple (TB) goes to the bov only (HKS SSQV in this case). So if that is true, where exactly does the vac line from the internal WG go? also I will be running a AEM EMS4 and the map sensor needs a source but im not 100% sure where to get that from, I hear some say never tee off of a source going to the map sensor. Any help/info would be greatly appreciated thanks in advance! |
![]() Join Date: Nov 2007
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
You can use the bottom nipple for a boost source for the wg but you'd be better off putting a nipple on the hotpipe for a boost source for the wg. You could T off of the vac line running to the bov for the boost gauge. I wouldn't tee off of the fpr source. As far as the map sensor source I honestly don't know what to tell you. I have the Greddy style IM and it has 3 nipples on the underside. I use one of those for the map sensor source and one for the boost gauge.
#3 | |
![]() Join Date: Jun 2010
as for tapping into certain vacuum lines, i dont think it's a big deal. i had 2 devices on each of the 2 upper ports on the TB. if you're worried, you can use a vacuum manifold that taps off of the brake booster hose. the WG signal should see boost only, so take it off a charge pipe. you can tap the compressor outlet or use a quick-tap. |
#6 | |
