S14 Liquidation Sale - fenders, suspension, kouki lights, etc
Cleaning the garage of parts I've accumulated over the years
and no longer need now that I don't own a 240 anymore Located in Pomona, CA (by the Fairplex) Pick up is preferred Prices are OBO within reason for pick ups I'll add more stuff as I go through boxes in the garage Driftworks Drop Knuckle set - Sold - the rears were modified with spherical bearings Progress sway bar - Sold - Arguably the best sway bar for the s-chassis - 3 way adjustable with rod ends - seen is the bar with endlinks custom made to fit an LS1 swapped car - will include a brand new set of hardware to install in regular set up http://www.progressauto.com/products.../productID/415 SPL new tension rods - Sold Peak Performance toe arms - $100 - Aurora bearings - some surface rust but good articulation and no play on bearings - the marks seen on them are from the previous owner diy alignments Ebay 5 lug hubs and Timken rear bearing set - $250 - the bearings were taken appart and re-greased with Redline CV-2 grease - never installed Nismo subframe bushings - $50 JDM fog lights - $150 - some overspray on body but in good shape Engine bay dust cover - $30 - keep you engine bay clean and reduce cabin noise - has a very small tear around a hole but overall in very good shape Steering column bottom cover - $10 Oem suspension - $20 pair 30mm kouki fenders - Sold - Was told these are Origin but not sure - passenger side has crashu damage but is fixable Nismo rear strut bar - $100 Sunroof assembly - $150 - it was given with an old s14 purchase but never installed, appears to be in good shape z32 new Moog tie rods - $40 - never installed Moog front balljoints set, new - Sold Tie rod boots - Sold JDM headlights with H1 hid bulbs installed - $450 - in great condition, no broken tabs USDM headlights with Xenon projectors - $450 - in good shape, no broken tabs z32 rear uprights - $30 Reinforced clutch pedal - Sold - in great shape, reinforced with welds as the Nismo version Kouki engine bar harness - Sold - complete, no connectors cut - from fuse box to SMJ connector - perfect for someone doing a relocation, zenki to kouki conversion, or fixing a shitty harness Steering rack - $150 Power steering pump - $75 - reservoir and lines includes Nabco clutch master - Sold Last edited by ManoNegra; 11-28-2014 at 03:58 PM.. Reason: Update sold items |
#6 | ||
which set of light do you want more pictures of? jdm or oem? |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() Feedback Score: 23 reviews
I think those Kouki fenders are Vertex man, I had some Vertex side skirts and they had the same serial number, anyways good price!!! GLWS...
[SIGPIC][/SIGPIC] http://wheelflip.com/r/Wheelwhore87 |
#8 | |
I wouldn't be surprised since I got these from a friend who took pride in the parts he installed on his car. Update, these items have been sold: - Progress sway bar - SPL tension rods - Moog balljoints - tie rod boots |
#17 |
#19 |
#24 | |
Yes
PM sent Quote:
If people ahead of you don't come through, I'll let you know. |
#25 |
ManoNegra I'm interested in both the clutch pedal and engine bay dust cover, I can pick up first thing in the morning. Hopefully you still have them...
