Help!!!
I have a 91 nissan 240sx hatch with a ka24de in it
im new to the 240 game but i know some things about cars here the situation i can crank her over and it ll start right up but it wont idle at all. I removed and cleans the aac and nothing i cleaned out the maf. Tired to start it up with out the maf and nothing but when i plugged the maf back in it idled for about 5 secs and then died back out. I also have a fuel leak idk what else it could be shoot me some ideas |
A fuel leak is kind of a big deal. I wouldnt even try to start the car until you have that problem solved. Poor fuel pressure would keep the car from running. If the leak is bad enough as soon as it starts and gets vacuum it will open the fpr and all the pressure will be lossed. Does the car stay running if you open the throttle or just die. Does the fuel pump stay on after the prime?
