Old 03-22-2017, 09:20 PM   #601
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Anyone here running a set of Kelford 184C??
Old 03-23-2017, 06:42 AM   #602
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Hey guys just posting to let you guys know that we have a shipment of Kelford 184-T's and Kelford 184-ST's coming in and they'll be on the shelf ready to ship in about a week. We're now going to start selling Kelford directly.
[email protected]
hanzbrady is offline   Reply With Quote
Old 03-23-2017, 11:38 AM   #603
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
@hanzbrady- Do you have a PN for NGK plugs with a removable plug tip to accommodate the CBR coils?
My SR20VET
Old 03-23-2017, 11:50 AM   #604
RalliartRsX
Trader Rating: (32)
jr-ss, if hanz doesn't find it, let me know. I may have the part number on my comp at home.
What are you using now btw??
Old 03-23-2017, 05:22 PM   #605
jr_ss
Trader Rating: (34)
I am running BKR7EIX PLUGS currently.
My SR20VET
Old 03-24-2017, 02:55 PM   #606
Mintyboy
Mintyboy's Avatar
Mintyboy is an unknown quantity at this point
Just started looking into sr20vet. I know people do these motors to get big numbers with a sr. Being that, almost everyone on here says not to cheap out on parts, with the appropriate parts, would you say they can be reliable motors? If so, at what hp would be its limit for safely running it? Hope that makes sense. Thanks
Mintyboy is offline   Reply With Quote
Old 03-24-2017, 03:19 PM   #607
jared420sx
jared420sx's Avatar
jared420sx is on the path to ruinjared420sx is on the path to ruin
Lol. Anythig can be "reliable" with the right amount of money and know how.
You need to be more specific about your goals as well. Go search some more.
jared420sx is offline   Reply With Quote
Old 03-26-2017, 03:35 PM   #608
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
Is anyone running a future fab manifold?
I am running one with a 38mm wastegate with a GTX3076, and i am getting boost creep!
My target boost is 18psi, and it's peaking to about 22psi.
I have the CP Pistons with valve reliefs, compression 9:1, is 22psi ok on pump gas or is that sketchy?
I still havn't tuned in the water/meth setup, so maybe i can tune that in to obtain 22psi?
Last question, SHOULD i be getting boost creep with my setup?
Drift team page
www.facebook.com/savageimpression
Options13 is offline   Reply With Quote
Old 03-26-2017, 08:38 PM   #609
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
maybe the 38mm is too restrictive with that?
di-devol is offline   Reply With Quote
Old 03-26-2017, 11:59 PM   #610
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
Have you tried to start with a 14psi base spring vs the 8psi spring it comes with?
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 03-27-2017, 12:57 AM   #611
Options13
Options13's Avatar
Trader Rating: (43)
there is actually a 6lb spring in the gate right now.
if my target boost is 18psi, should i be running a different spring rate?
ALSO, i am using the aem boost control integrated in my ECU with the aem solnoid.
Drift team page
Old 03-27-2017, 05:32 AM   #612
jr_ss
Trader Rating: (34)
You should be running close to what pressure you want so that gate doesn't have to regulate large amounts of air.
A 13-15lbs spring would work better for your situation. However, 38mm may not be up to the task. I have 44 on my GTX 3076r and I don't have creeping issues. I'll spike past set pressure but it settles within 1 psi to desired. I'm also running a PeakBoost manifold.
With that said, I'd start by changing springs out to see if that helps.
Anyone have any insight to the Spark plugs I requested earlier?
My SR20VET
Old 03-27-2017, 06:03 AM   #613
RalliartRsX
Trader Rating: (32)
Rule of thumb is; double the gate spring pressure is typically the "max" it should run at + or - a few psi. I think you are above that limit and I would bump it up to a 10-12 psi spring to give you some headroom.
jr-ss, I thought you received the info from hanz. Let me reach out to my buddy Ashton to see. Sit tight (send me a PM in afternoon in the mean time to make sure I do not forget).
Old 03-28-2017, 05:46 AM   #614
jr_ss
Trader Rating: (34)
I called NGK yesterday because I could not find what I was looking for. I spoke with someone from tech support; They DO NOT make a threaded terminal spark plug in 5/8 hex. They have one in the 13/16 hex, but if I'm not mistaken, that is too large for us to use in these heads.
So, I'm searching for quality plugs that use the threaded terminal stud in 5/8 hex. Anyone have anything I can look into?
My SR20VET
Old 03-28-2017, 05:52 AM   #615
RalliartRsX
Trader Rating: (32)
jr., I reached out to my friend twice with no response. Not sure what the deal is as he is seeing my messages
Old 03-28-2017, 06:42 AM   #616
hanzbrady
hanzbrady's Avatar
Hey guys, the part number you need is Denso:IK24, IK27, IK31 The numbers dictate head range. Generally street cars are happy with the 24's
[email protected]
Old 03-28-2017, 06:47 AM   #617
RalliartRsX
Trader Rating: (32)
And there you go jr
Thanks Hanz!
Old 03-28-2017, 07:28 AM   #618
speedingmofa
speedingmofa's Avatar
speedingmofa can only hope to improve
Guys, can i get a bit of advice on what type of bearings to use for a vet setup?
Block has been machined with oil groooves (sr20ve style, i think the gtir also has them machined) to accept gtir 5-hole bearings.
It's a daily driver with the occasional track/drift use.
I'm sort of leaning towards ACL race or Kings bearings, but i'm having doubts wether to maintain the loser end of the standard recommended clearance (according to FSM 0.025mm) or use the X (+0.025mm/0.001") bearings.
Motor will see max 8.5k rpm on 16ve cams, supertech S+R, HX40 on TS exh mani
And has anyone been able to fit a 4" elbow+downpipe in a LHD s14?
Need UKDM/EUDM/JDM/RHD Nissan parts? Hit me up
Insta: skids14
speedingmofa is offline   Reply With Quote
Old 03-28-2017, 08:04 AM   #619
s13silvia123
s13silvia123's Avatar
which one dictates what heat range?
Old 03-28-2017, 08:21 AM   #620
hanzbrady
hanzbrady's Avatar
24, 27, and 31 are the heat ranges.
[email protected]
Old 03-28-2017, 08:24 AM   #621
hanzbrady
hanzbrady's Avatar
We use ACL on every build at the shop when they're available. Use GTi-R bearings, and I'd recommend using a 19mm rod bearing however they require rod machining. Don't bother with HX bearings unless you need them, we also shoot for factory tolerances.
[email protected]
Old 03-28-2017, 08:29 AM   #622
speedingmofa
This might help
@hanzbrady Thx for the reply bud! Are those regular ACL's or the Race's types? Unfortunately, crank has alraedy been externally balanced. So i will be using the regular 17's on the rods
Insta: skids14
Old 03-28-2017, 08:30 AM   #623
Rb26kouki
Rb26kouki's Avatar
Trader Rating: (62)
Rb26kouki is an unknown quantity at this point
Feedback Score: 62 reviews
I had the same issue with a GTX2867r did a 44mm gate boost creep went away
Rb26kouki is offline   Reply With Quote
Old 03-28-2017, 09:16 AM   #624
hanzbrady
hanzbrady's Avatar
This might help
We use ACL race bearings. As for what you just said, all sport compact engines are internally balanced, not external just figured I'd clear that up.
[email protected]
Old 03-28-2017, 09:39 AM   #625
speedingmofa
What i meant is that it was balanced by itself. Balance was then checked with flywheel attached. Never saw the procedure with my own eyes though.
So that's called individually balanced then i suppose?
Insta: skids14
Old 03-28-2017, 10:12 AM   #626
hanzbrady
hanzbrady's Avatar
What i meant is that it was balanced by itself, i think with the flywheel or some weight attached where the flywheel is supposed to be. Never saw it being balanced with my own eyes though.
Well there's essentially two types of engine balancing, external and internal.
V shaped engines, especially old school V8s will be externally balanced meaning that the flywheel and balancer have counter weights on them to correct the imbalance in the crank and rotating assembly.
On sport compact and inline engines you have internal balancing, meaning that since the action of two pistons simultaneously rising cancels out harmonics found in V orientated engines. This way you just have to balance the crank and the rotating assembly by themselves. All sport compact and inline flywheels, clutches, and dampers are "zero balance" meaning that you can change them without ruining the balance of your engine.
[email protected]
Old 03-29-2017, 03:41 PM   #627
jr_ss
Trader Rating: (34)
I ordered a set of IK24's. I should've ordered some IK22's to keep the heat range the same. We'll see how the car responds with it.
My SR20VET
Old 03-29-2017, 08:17 PM   #628
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
+1 for ACL bearings. Bluemoon did my assembly and thats what they recommended (of course, WPC treated, for overkills sake)
Old 04-07-2017, 06:16 AM   #629
s13silvia123
Cams and Turbo setup!!!! + supporting mods
What are you go pushing with the twin scroll GTX3076 turbo? I want at least around 550ish HP. This is the only turbo i have laying around besides a greddy 18g. I want to see who's doing well with the twin scroll GTX3076 and what numbers are you guys putting up so i can determine on cam setup.
Old 04-07-2017, 06:58 AM   #630
RalliartRsX
Trader Rating: (32)
Soooooo..............Anyone using Kelford 184C cams??
