rb25 leaning out after warm up
I have an rb25det series 1 and it has been running lean since I got it. My spark plugs all turned white and it hesitates under load. I installed an innovate LC-1 wideband and it reads fine for the first minute or so until the cold idle falls and then leans way out to like 22. I replaced the fuel pump (walbro 255) and maf. Same symptoms.
Everything is stock and no trouble codes. Any ideas / suggestions? Thanks. |
![]() Join Date: May 2009
It shouldn't run the same like that. With the MAF unplugged with should not be able to rev above 2000.
I know with all the 4 bangers you need to retune for the z32 MAF. I say search and find out what your MAF voltages should be. |
