I got a bunch of random parts laying around that I don't think I'll be needing anymore. If you don't see a price on a part than just ask and or make me an offer. I will ship anything as long as buyer covers shipping.
Circuit Sport engine torque dampener: $60 Circuit Sports Brake master cylinder stopper brand new:SOLD S14 Air Idle Control Valve: $60 Lower water neck w/Nismo thermostat:$50 Upper water neck:$20 O2 sensor fat type w/ harness:$50 Under plenum water lines and brackets:$25 Stock location turbo elbows w/gaskets:$15 each Stock location turbo oil line:$10 Oil dip stick and tube:SOLD SR20 Crank Pulley:$30 SR20 cam gear:$15 SR20 radiator hoses:$15 Radiator brackets:$10 Stock pcm valve thingy:$10 S13 Fuse/relay box bracket:$5 7 Layer exhaust manifold gasket almost new:$25 S14 Intake Plenum:$40 S14 throttle body:$40 S14 intake mani gaskets:$10 SR spark plug gasket:$5 S13 intake manifold gasket:$5 S13 trunk privacy cover clean:$50 S14 cams clean:$60 -10 AN treadstone/Earls GT oil drain flange w/ hardware: $30 A/C Heat control unit and blower ducts all under dash parts:$75 Last edited by ETHANOLED SR; 09-26-2010 at 02:37 PM.. |
[QUOTE=infam0usndn2nv;3655706]u got alternator adjustment bolts?[/QUOTE
No alternator adjustment bolts! pm sent. Yes it will work with the Z32 m.c. as well as the stock ones. |
#10 | |
460
