![]() Join Date: Mar 2008
Trader Rating: (36)
![]() Feedback Score: 36 reviews
*SoCal* JDM Type X aero, Cusco roll cage, Z32 brakes, window visors, Priced to sell!!
Hello fellas, I have a bunch of parts that I need to get rid of to help fund the purchase of a new(er) car for the wifey. I'm parting out the 240sx and these are the parts that never even made it on the car haha. All parts are priced to sell. I'm open to shipping as long as buyer pays shipping costs. All parts sold as-is.
For the quickest response, email me at acousticnacho22(at)yahoo.com 1 Genuine JDM kouki type x bumper foam support - front. If you don't want your type x bumper sagging like a old bag's bags then this bumper support is a must! Purchased brand new and still in original packaging. Works with all years s13 crash bars (chuki crash bar requires little work). $50 SOLD SOLD 2 Chuki 1991-1994 crash reinforcement bar. Great condition. The whole piece is very straight! By removing the stitch welds from the tabs on the left and right ends, this piece will work with the type x foam support above. Don't throw away $140 on a type x crash bar when this once gets the job done for much less. $35 3 JDM taillight lower panel (panel only) in white. This piece was bent during shipping from Japan (not uncommon) but it straightens out by hand every time. Only noticeable if you're looking for it. $50 4 GP Sports style roof wing. This piece has never been installed. Just add double sided stick tape and you're good to go! This subtle roof wing goes great with sleaker aero like chuki skirts and trunk spoilers. $70 SOLD SOLD 5 Solid 1-piece rear strut tower bar. No lateral play. Your traditional strut bars use multiple pieces held together by sometimes loose-fitting bolts which will inherently suffer from lateral play. This strut bar is so solid, the rear-end has to be lifted just to install it! $95 6 Set of Hoosier R6 race tires 245/40/R17 ($258/each new). This makes for an ideal square track-ready setup. One pair has only 3 qualifying laps of use. the other is unknown but the wear indicators show plenty of meat left. Radial R6 tires are Track & Competition DOT tires developed for drivers who compete in road racing where responsiveness and high levels of grip in hot, dry conditions are desirable. Radial R6 tires are designed to reward drivers with fast, consistent lap times and extended wear due to their traction and handling. $520 7 z32 aluminum rear uprights or knuckles with cone bushings included. Ushings are in good condition. ll you tracks junkies out there, you need this! Drop significant unsprung weight and increase road responsiveness! $80 8 Front strut bar with black end pieces. Blends in with the factory engine bay very well. $45 9 OEM black carpet for S13. This is the plushier version ('89-'90). Believe me when I say that the third party carpets (stockinteriors.com, etc.) are a PAIN to install. All the cutting and measuring and undoing and redoing gets old real fast. This OEM carpet is ready to be installed pronto! $75 SOLD SOLD 10 Cusco 7-point roll cage for S13 hatchback and should fit coupe [zilvia.net et al]. All bars includedand they are padded and ziptied in the critical areas. Missing hardware. Surface finish is in rough shape but that's an easy fix. Never got around to installing it. $450 11 z32 aluminum 30mm front brake calipers. Very good condition! Currently running stock setup? Step up your game with 4 times the pistons. Currently running z32 IRON calipers? With aluminum calpiers, you can drop a significant amount of unsprung weight and increase road responsiveness. You really can't go wrong with these calipers no matter what angle you're coming from! $210 12 pair of brand new speed bleeders. Self-explanatory. $10 13 Genuine JDM Nissan window visors for S13 hatchback BRAND NEW! Give your hatch a sleeker look with the mint condition window visors and avoid the long shipping wait from Japan. Never been installed. $110 SOLD SOLD 14 Genuine JDM kouki type X rear valance for S13 hatchback (All 3 pieces included) - OEM black paint. Good condition $330 SOLD SOLD 15 brake shield for S13. Constructed of heat resistant steel. Much lower thermal conductivity than aluminum means smaller increase in temperatures for the same amount of heat. $20 16 Passenger side headlight assembly with headlight cover (OEM black) - $50 $50 17 Driver side headlight covers OEM black - $15 (2 available) $30 18 JDM oil cap (removed from my SR20DET) $5 19 S13 air panel for chanelling air through radiator more efficiently. 3 piece but don't have pic of the side pieces at the moment. They are brushed aluminum finish. $40 SOLD SOLD 20 S13 SR20DET Oil pressure switch ( 1/8” BSPT) Brand new $10 (2 available) Both brand new. $20 21 S13 SR20DET Mass Airflow Sensor MAF. It is used but fully functional. - $40 $40 22 S13 SR20DET MAF adapter with 3”*outlet. The adapter is constructed of lightweight aluminum $25
![]() Join Date: Jan 2010
Trader Rating: (26)
Is that roof wing for a coupe or hatch?
Interested in: Roof wing [if for hatch] MAF adapter Hatch visors Cage Carpet #/f/sale-items/46533...ore-f-t-s.html See anything you like? Only got what's left on the list. |
#4 | |
Trader Rating: (36)
