My question is will the infiniti M30 rear brakes fit and directly bolt on to the S13 with no modification and would I still have a fully functional e-brake? Also would it even be worth it to even attempt the swap in?
Being a Floridian is a birth right! |
M30 rear brakes have the integrated parking brake assmembly in the rotor "hat" Sooo it would be like a z32 300zx setup. Never tried to bolt it on a 240sx. I would be willing to bet it would bolt on, but i doubt the e-brake cable would work. Why not just do the Z32 setup since it has been done before?
I just wanted to find a simple bolt on upgrade for the rears, just like the Q45 fronts but if thats the case I'll just keep my factory ones and just upgrade the pads or probably do the Z31 conversion. Thank you for a response.
