L1 swap parts, driveshaft, radiator, fuel system
Hey guys a few last parts from swap part out!
Daft innovations aluminum drive shaft: $425 Tucked radiator with shrouded fan: $500 almost brand new Full fuel system: $1000 This fuel system is able to support 1000hp with bigger injectors on gas and 800 on e85. Walbro 400lph intank pump -10 feed to fuelab fuel filter -10 to Y block splitting into 2 -6 lines feeding each fuel rail -6 off of each fuel rail to fuelab fuel pressure regulator -6 return from AFPR to tank Summit racing billet fuel rails Stock ls1 injectors Will be adding photos later. Email: [email protected] Cell: 317.442.5861 |
| driveshaft, ls1, s14, turbo, walbro |
