![]() Join Date: Jun 2008
S14 rear toe alignment
Well i want my toe to be zero
But .10 and .14 is in the green and the techs Are saying that is 0 Buy my wheels still looked toed in Should I make it 0 even tho the machine is saying That's red |
![]() Join Date: Aug 2006
Trader Rating: (105)
![]() ![]() ![]() ![]() ![]() Feedback Score: 105 reviews
I was looking at my alignment sheet from Les Schwab and it says the rear Specified Range is between 0.00 and 0.23. I was at the alignment machine and it was showing stock was about 0.07. Looks like you are within spec, but I'm not sure how much of a difference it would make if it was zeroed out.
PM me for s13 or s14 parts! |
![]() Join Date: Mar 2008
![]() Feedback Score: 21 reviews
your wheels will look toe in from the side of the car. Look at it straight from the back and even then, it's still sketchy.
You ARE within spec and that little toe won't make a big difference. You don't NEED zero. |
