LBC: ddrug coilovers // jdm valances // kouki lens // z32 rotors // s14 seats // FREE
I will be in the Long Beach area on the 21st!!!
Shipping is an option for most parts. Shipping and PP costs are not included (unless stated otherwise). All parts located in the Bay Area, CA. Local pick up is preferred and has priority. --- ddrug coilovers for s14 with external resorvoirs --- SOLD -super short stroke coilovers, they go really LOW and are dampened very well -mono tube construction with huge 47mm valve, 40 way adjustable -spring rate is upgraded, special order 10/8kg -used for less than 10k miles -NO stripped studs, broken studs, cross-threaded studs, or damage at all! -NO signs of leaks or blown struts! -always used anti seize on strut body threads so NO seized or frozen collars! -adjustment wrenches included -true JDM coilovers --- BNIB s14 JDM kouki "dummy" lens/signal extensions --- $55 --- brand new shineauto s14 jdm rear valances --- $200 --- s14 passenger side seat in solid base model light gray --- $80 --- s14 rear seats in solid base model dark charcoal --- $45 --- front z32 30mm rotors. used, but in great shape with plenty of life left. will include axxis ultimates that have less than 25% meat --- $38.21 shipped with PP fees included --- s14 passenger side airbag. unblown with pigtail --- $15 --- brand new billet aluminum differential bushings --- $45 --- FREE STUFF --- $FREE (ABSOLUTELY NO SHIPPING): -s14 passenger side window and lock panel -s14 dome/map light panel -s14 dome/interior light assembly
#4 | |
Coils have been sold. BUMP!!!
