![]() Join Date: Mar 2012
SR20 swap, no low throttle
Ok this is hard to explain so I'm going to do my best but if you need clarification or a video I'd be happy to post further.
Anyhow I swapped in an SR20det blacktop into my 240. Everything runs fine, idles normal, has alot of power, etc. The only issue is that I have no low throttle. For instance in neutral, if you slowly apply throttle, nothing happens until a point where it's like all of a sudden the spark plugs start to fire and the rpms climb however once they "catch on" the revvs climb to redline, it would be impossible to hold it at say, 3,000 rpm. When driving there is no low throttle, I constantly have to accelerate and let off the gas over and over to maintain speed. I can't just hold a steady throttle placement and hold say 45mph, either I have to depress the throttle far enough where I will cross the threshold so to speak and the car will accelearate, if I slowly let up on the throttle it hits a point where it just cuts and coasts like you let off the accelerator all together. I can't be certain but I think the injectors are still firing, the spark system just isn't sparking at low throttle....odd. I don't even know what to search for on here to try and remedy the issue help? lol -Matt
![]() 94 240SX, 93 Stealth, 92 VR4, 93 RX7 , 88 Yota |
Any chance KA and SR sensors are the same? I checked the tps at idle to see if it was right while looking for vacuum leaks but I didn't check for the full motion since I can't find my alligator clips
if i remember it should be .45v closed. slowly move it with a mutli meter and watch the voltages. see if it jumps. pretty sure they are different sensors, but i cant confirm
Sounds like bad data into the ecm, probably timing is waaaay off and/or tps is bad....and/or maf is screwy. Yeah check if it does the same sitting without driving i.e. TB as previous poster above me mentioned as well.
Like Me on FaceBook !
