![]() Join Date: May 2003
What Spec Wheels Does Everyone Have?
Ok to unclutter the forum and help on peoples questions on fitment of wheels, im starting this thread for people to post what size/offset wheels they have and if they clear there brake setup(if not stock) and if it clears their suspension(if not stock). I think this would be a good way to do it, post pics too if at all possible, this should help everyone.....
ill start with my temporary wheels....... Old School 280zx Turbo Swastikas 15x6 +12 offset They wont clear z brakes but they would coilovers ![]() |
![]() Join Date: Feb 2002
5Zigen FN01R 17x8s +35mm all around with 225/45 tires
Clears Eibach Sportlines on KYB AGXs just fine
2004 Honda S2000 NFR | 2007 Acura TL CBP | Project ***Coming Soon*** |
![]() Join Date: Mar 2003
ugly poo-poo 15x7 wheels +10 offset though. 195/55/15 Works fine for me. Clears my coilovers, but I don't know if they will clear Z brakes. I'll find out soon enough.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing. |
![]() Join Date: Feb 2003
Great Thread! this could be a valuable resource if everyone posts their wheel fitment.
All I can contribute is '02 Nissan Sentra SE-R SpecV wheels 17x7 +47ish offset. ![]() worse brake clearance than stock 7 spokes, also less suspension clearance. -Matt
'89 Nissan 240SX fastback: #23 DSP/RallyMod2/Track Slut '95 BMW 540i 6 speed: Ultimate Commuting Machine PFM Racing www.solo2.org www.midwest240sx.com Last edited by Rennen; 01-25-2004 at 10:30 PM.. Reason: offset |
#8 | |
![]() Join Date: Jan 2003
I must break you. |
![]() Join Date: Nov 2002
R33 GTR 17x9 +30 (will clear Z/R32.3.4 brakes, etc..) (WILL NOT clear JIC FLT-A2 without 5mm spacer).
FN01RC 17x9 +15 (everything) WHAT I RUN, since it is different: 17x9 +10 (20mm spacer on GTR wheels, 5mm on FN01RCs) all around 215/40/17 F 215/45/17 R, sometimes 225/45/17 (on the UGLYASS 5Zigens) This is on PS13 COUPE (yeah thats right... 180sx what?) with stock fenders (rolled and slightly pulled) GOOD pics will be posted once i take them. Old pics suck cause its not this current setup (diff. tire sizes). |
AutoX Junkie
Borbet Type-T
16x7.5" +35 offset 19lbs. (heavy!) 225/50/16 Victoracers clears stock brakes, should clear Z brakes just eyeing it. clears stock shocks by 1cm. |
![]() Join Date: Oct 2001
I have 15x7 Black 5star American Racing with +35 offset (which I am giving to my gf to put on her 240)
I have some 15x7 Riken Meshs with a 0 offset, I have some crazy oldschool 15x7 with a -2 offset, Ill get pics ones summer comes, Also all my wheels clear coilovers, but non of them clear the brakes. Ill more than likley get some K1s for the front if I ever get bigger brakes, and just rock a spacer. |
![]() Join Date: May 2002
16x7 0 offset 205/45/16 (i forget) and 215/45/16
clears coilovers, not zbrakes due to being a mesh w/ lip...spoke design ![]() before camber ![]() 15x7 +27 kosei K1 205/55/15 clears coilvoers AND z brakes, no spacer rear is 15x6.5 +14 or so clears coilovers, not z brakes 205/55/15 ![]() weeeeeeeeeeee 15x7.5 +17. needed 30mm spacer to clear z brakes well. cleared coilovers w/o spacer 205/55/15 ![]() ![]() rear is same as previous ![]() damn my 'sleepy eyes' look sooo gay that high! haha front is 15x7 +27 kosei k1...same as before rear is 15x7.5 +17 ..same as before ![]() front kosei k1 rear ssr longchamp xr-4 15x7.5 +5 clears coilovers NOT zbrakes 205/55/15 ![]() ![]() rear is 15x7 +15 SSR Reverse Mesh clears coilvoers NOT zbrakes 205/55/15 ![]() blitz type 03 17x8 +28 215/45/17 WILL NOT clear coilvoers/zbrakes (in this offset) used 20mm spacer ![]() i cant find more pics..super sunk. blah front demon camber 205/55/16 16x8 -15 (yes negative 15) will clear coilovers and z brakes (thanks for the loan sam--jspec.com) ![]() rear is same as before (blitz 17") ![]() wide fenders REQUIRED ![]() ![]() and where im at now 17x9 +15 5Zigen Fn01rc 215/45/17 clears coilovers and brakes ![]() ![]() |
#17 |
they are cool if you want to keep that old look (zenki/chuuki)
personally i like the modern look....soo out w/ the mesh 15s... all those wheels have been owned over the period of 1.5 years! so many wheels, so little time. i also had a set of z32 wheels and some more steelies, and SE wheels as well as some other mesh ones..haha..too much i have 6 FN01rc 17x9 +15 and more wheels coming up soon.. |
WOW addicted
![]() Join Date: Dec 2001
Nismo LM-GT2
front: 17x8 +35 215/45-17 (less than finger width b/w tire and spring. Would not clear coilovers with a wider tire.) Rear: 17x9 +38 215/45-17 (can fit my entire hand b/w tire and spring.) clears z-brakes. ![]() ![]()
#21 |
Work wheels... 18x8.5 +32 front... 18x10 +40 rear... I have RS*R's and AGX clears with a bit of room... Ohh and 235-40-18's front and 265-35-18 rear...
I'm guna buy the Tein flex and pull my fenders to add some spacers... Or just get new wheels. Thats a later mod... turbo next EDIT: Forgot to add... This is on a 240sx-se S14
http://www.cardomain.com/memberpage/509537 http://www.imagestation.com/album/?id=4287415487 #/f/showthread.php?t=21036 |
#22 |
it's NOT a show car!!
Stern Face II Beast 18x8.5, 18x9.5 (offsets to be determined soon) Sorry I just don't know the offsets because I had the centers swapped...
NAKAMA | ROOTS RUN DEEP |
#23 |
Dirty D, you forgot to say that in most of those pics you were running a (30mm?) spacer with your Kosei's. 15x7 +27 is not that FLUSH even though it clears brakes and coils...
And also, you have 17x9 +10 (copycat) up front right now. 5mm spacer cause Tein HE's have teh suck collar design... Man, do i have to do eveything for you? |
#24 |
Mine are i believe Riken Mesh or Enkei Type 88, 15x7.5 not quite sure how to tell the difference with +15 offset..
I'm looking for the same identical wheels in 16x8 +0 Offset.. if you know someone let me know, tks |
#25 | |
on strike three.
#26 |
Gram Lights 57S 17x8.5 +22 215-40-17 17x9.5 +22 235-40-17 Works S1C 18x9 +20 225-40-18 18x10 +13 245-40-18 rolled fenders up front pulled fenders in rear Last edited by Heartwork; 01-26-2004 at 04:42 PM.. |
#27 |
Hey Heartwork, is that your friends S13 in the back ground? the one w/gold SSR's? Do you have the specs on those? SSR Reverse Mesh doesnt come in gold from at least what their website says, any info on this? pls let me know, tia
#29 | |
on strike three.
#30 |
um..when the front 215/45/17 are slightly under front fender..it rubs. juuuust barely. a 3mm spacer should clear it ok. i only had a 5mm front lindsay hanging around.
