![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
I'm picking mine up 2morrow, so I can ask, since I'll B at the wherehouse. Can you post a pick of what U R referring to so that I have a better idea, or can actually so them this post. This is good info.
Thanks.
![]() (888) 611-1776 |
1 of the sales reps said that these are used with the Z32/JDM 5 lug conversion. They are supposed to be used as spacer for the bottom pins that bolt the shock/coilover to the brake/wheel components. Unless, you have this setup, you basically don't need them.
