trying to clean out the garage round two so heres some stuff i've been holding on to
rb20det/KA24 JWT clutch with exedy chromoly 13lb lightened flywheel
this clutch definately will hold almost any power you can throw at it, i was running 650whp / 548wtq on this clutch without any slippage.. jwt rates it to 600wtq but that is conservative im sure.. this clutch only has 3000miles on it so it's got plenty of life left.. got a little bit of surface rust on flywheel because its been sitting a few months but in overall good condition
only reason im selling it is because i switched to auto tranny for the drag car so my loss is your gain.. bought it new for $450 (clutch) and $350 (flywheel) asking
$450 shipped
This is a JWT RB20/KA24 pressure plate/clutch disc the pp has minor surface rust but is definately still in spec and clutch disc has 3.70mm of meat left on it so thats about 15k miles (bought new for $450) asking
$150 shipped
KA24DE knock sensor
$35 shipped
Q45 Ring and pinion gear This is a must if you are making big power, direct bolt on to any r200 diff its got 3.54 ratio that means you can make big power with this r&p.. i love it because on freeway at 75mph im only at 2600rpms in 5'th..
SOLD
