![]() Join Date: Feb 2007
alternate to a nismo thermostat
i remember reading somewhere that there was a thermostat off another car that would open earlier like a nismo thermostat but my searches have come up empty.
anyone know which car it was from? |
![]() Join Date: Dec 2006
![]() Join Date: Mar 2003
several places make Thermo... most are about the same prices.
Nismo Sard ARC Billion If $100 is to much (IYO)... then get the Nismo... if you want options and the absolute best... get Billion!! -Drew |
AFC #1
![]() Join Date: Oct 2003
![]() Join Date: Sep 2006
dunno
today the temp out side is 46*C... ..My s14 is fucked in this weather....i've tried running "colder BS" t-stat but they work the same....2007 pathfinder have the same t-stat as the ka...open at the same temp too FAIL C no i'm running my car t-stat LESS...it's the same with or with out... ![]() NINJA edit : some one delet my link WTF?
'95 S14 Se With HKS's - BREMBO's - ES/SPL. Last edited by Ali 556; 05-22-2009 at 04:11 PM.. |
#12 | |
76.5c = 169.7 *f 82.22 c = 180 *f 195 f = 90*c
'95 S14 Se With HKS's - BREMBO's - ES/SPL. |
I have the Nismo Thermo from West Cov.
Combined with a Alum Koyo Rad and Dual E-Fans My Defi Temp Gauge Never goes above 70*C (158*F) always stays around 67*C
#17 |
at the track this weekend i was hitting 220 after 2 laps and i'm running koyo rad, nismo t-stat, dual fal fans, and water wetter... then i let it idle to cool off came back 5 mins later and i was at 260!! fans were fine.
^^ 260??
![]() I have warnings set for 190... 200 - 210 is getting hot... 260 is near death!! Cooling Systems are very simple... only have a few components (all replaceable) ... if you have one part wrong the system will not be optimal... most critical that gets looked over is the fan shroud!! -Drew |
#19 | |
![]() Join Date: Jan 2007
The temp went up while idling? Fans definitely aren't fine. Should put your clutch fan back on.
#21 | |
yup rinning a good sized oil cooler to. infact when the water spiked at idle the oil temps were fine. and as for the shroud i'm running the 240 specific fal fans that come with a shroud. and i was running a stock fan before and was still getting overheating issues. and before anyone asks yes i also properly burped the system. |
#22 |
What gauges are you using?
#23 |
autometer cobalt. i've never had an issue with the gauge before.
here is a bit more info for those who may be able to help. s14 sr into s14 fmic koyo rad dual fal fans nismo t-stat water wetter and 50/50 mix properly bled the system 1 min on the track hard drifting and bang over heating. now normally i would just idle the car and the temps would come back down to 165 within a few mins but this last time the temps actually crept up. once i noticed it i shut the car off but ran the fans. after 2 mins i turned the car back on to let the water circulate and the temps cam back down quickly to 180 and then gradually back to 165. there is no leak as the reservoir is still full, the pump must be working since it is circulating the water, so i have no idea what i'm doing wrong. as you can see i'm leaning towards the thermostat but even that seems unlikely b/c the temps do come back down which means the thermostat is opening. |
#24 |
if you live somewhere really hott all the time, you can get away with no thermostat. i did that here and it just takes the car a really long time to get warmed up. but it was also 15 degrees outside. soooo the choice is yours. if your car is hitting 260 degrees slap dsm badges on it there is no reason it should get that hott
NO HANDS IN PANTS!! |
#25 | |
the cobalt gauges work great. my only thought would be the ratio of coolant to water. royal purple makes a coolant additive that drop the temps even further, its almost like freeon for your coolant system.
#28 |
possibly need an oversized W/P pully
at high RPM your probably Cavitaing the system.
#30 | |
Wouldnt it be the opposite? There is no excuse for 260*f, either there is an air pocket forming at the thermostat or your water pump is dying. -which probably would show the opposite due to warm coolant from he engine not flowing to the sending unit. Your probably boiling coolant in the head thus creating large pockets of air to end up behind the thermostat, preventing it from opening. |
