FL: Ka24e-T T2 bottom mount
I have a complete T2 Turbo kit for the single cam KA motor.
This is actually Jordan Gladman's first t2 set up he made. . I had plans on putting it on my car this spring, but I've decided to go with other plans. Kit includes the following: S13 Sr20 t25 Turbo ( I have an s14 T28 also) Bottom mount Turbo manifold (puts it in the same place as an sr20) Megan Turbo elbow Megan Downpipe ( w/ flexpipe and welded bung for wide band) Front mount intercooler Blow off valve N62 Mafs (with pigtail) 550cc injectors ( w/ clips - from Rx-7 turbo) Nismo FPR Steel braided oil feed line Rubber water lines Rubber oil line Chipped ecu Manual boost controller Basically everything needed to get the car up and running. I am currently located in Gainesville, but the kit is located at my mothers house in Orlando. I'm asking for $1100 for everything, local pickup. $1350 with the t28. I really down't want to part this kit out, but if I get enough interests, I will. I am willing to ship, but at buyers expense *Not my picture. **This is Jordan Gladman's car circa Spring '09 |
I've sold almost everything from this set up (turbos, manifold, intercooler piping etc) except for the ecu. Previous owner tuned the ecu for 300zx maf and 550cc injectors, but I dont remember which shop did the work though. Moates I think was the name.
