Hi,
Looking mainly for an S14 speed sensor. Need it cause I got an S13 speed sensor and it's reading double my speed. Also looking for some electronics and other parts... [x] S14 Light switch stalk with Fog light options [ ] Black passenger side door sill. [ ] Trunk carpet, grey & clean! Just the main bottom piece. [ ] 5 spd shift boot/trim [x] Clutch master & slave cylinder to replace mine. MC is leaking. [ ] Boost controller; prefer the AVC-R or Greddy Profec B 2 I need a DRIVE SHAFT ASAP!!! Manual drive shaft for an S14, non-abs. -- I want these and will need these eventually, but not now -- - 5 lug hubs - Z32 Brakes All for an S14. And will be shipped to 98031. I am PayPal ready. Last edited by daftphunk; 11-02-2010 at 03:17 AM.. |
Bump this, I need an S14 Speed Sensor from a MANUAL Transmission if you didn't know already! ASAP!
I also ended up getting a Master Cylinder already as well. I might get a slave soon. Really want the SE Light Stalk, door sill and hubs right now. |
![]() Join Date: Oct 2005
I got a door sil, Greddy profec B spec 2 controller and used nismo slave cylinder with braided flex line. I also have the switches for the lights but its for a RHD. lmk.
No $$$ for some hubs etc. right now.
I need a drive shaft ASAP though! Looking for an S14 Manual Drive shaft, non-abs. I might be able to get away with the front section, but I need to get rid of mine. May even consider an aluminum one. |
