![]() Join Date: Aug 2011
Removing S13 RLCA to spindle bolt ?
Hi guys,
i finally finished installing my front arms correctly, and am now adapting the rear ones. Everything was fine, until i went for the ball joint bolt, on the spindle, that connects to the RLCA ... How i am even supposed to remove that one ?!? I had to use a socket and a long breaker one on the front, with tons of WD40. But there is no room to put a socket on the rear one ... Please tell me there is a way i did not see, and that i dont need to remove the shafts ![]() |
![]() Join Date: Dec 2010
Trader Rating: (28)
![]() Feedback Score: 28 reviews
Honestly removing the axles is the best way to go about doing it. Be really hard to break those bolts loose/getting the bolt on/off with the axles in the way. I mean Taking the axles off is a a decent mount more work but probably alot better then kicking/screaming trying to get those bolts off.
Ok then, will do ... i am really growing tired of having to dismantle half the car to get a bloody bolt every time. I really hope that is the last time ...
