Old 03-11-2012, 12:01 AM   #1
RBvert
RBvert is an unknown quantity at this point
s14 96 S14 Ignition Switch pigtail problems
so I've tried searching for the answer but for some reason the search function is broken for me Anywho so I took out my dash and main harness (long one) to repair some bad wires, remove a poorly installed aftermarket alarm and to replace the partially melted pigtail for my ignition switch but I lost the diagram I made and I'm screwed as no parts store or Nissan dealership in my area has a wiring schematic for an S14....
I've attached pictures of the switch electric assembly and the wires from the harness side of the pigtail.
RBvert is offline   Reply With Quote
ignition, ignition switch, s14, wiring, wiring harness
